If the chips in marble are relatively small, you can use a clear epoxy resin to fill them in. When hardened, if the epoxy is too glossy, buff off the shine with a 0000 steel wool. The epoxy will take on the look of the marble beneath it.
For more info on this topic, use the "Find" feature at the top of this posting to search for "marble repair".
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
