Judging by the clock's appearance, I would think the case was made around 1910 - 1920, but it could be later.
Whether the movement is original to the case I am not so sure. Others with more knowledge of French clocks may be able to date it better.
JTD
Yes that is in line with my own thinking and that of another interested party exactly. I think its the original movement as its fitted so snugly. The case is slabbed and veneered. Inside the space has bored out as a circular tunnel by some large lathe I should think. There is a space for the pendulum to swing in between the slabs cut away before they were joined I should think.
It suits me to say "Edwardian" 1900-1914 when WW1 would have interrupted everything. Yes it could be early 1920's but by then the mantle clock cases were becoming cabinets often made of boards and indeed veneered plywood.
The irony is this is just the sort of thing my pattern maker father (b1900) would have known all about.
Got to just say that these old French movements work really well. They have little extras like the frontal adjustment of the rate. There are ways to phase and time the strike without having to split the plates again. {Small removable pivots that allow re-meshing of the hammer and strike lift}. They keep good time too for 8 days winding routine but will often run 14 days end to end at the sacrifice of accuracy. Back in that period they would have had to have been more reliable and accurate/ Pre-wireless I suppose it was referenced to a sun-dial eh?
Thank you for you interest.
Rgds, BerryG
Hi,
I would place the date of the clock around 1890-1900, and fully agree with JTD about the case. It almost certainly isn't original, I would be very surprised if it was. What does the stamp on the back plate say? It should be that of the manufacturer, probably Japy - but it is too blurred to make out in the pictures provided.
Regards.
Thanks for your interest and the response.
There is no makers name - only a round stamp "Marque Deposee" which is a French registration or patent - as I understand it. I think various makers were involved and they started C1800. The numbers (serials) are not very easy to read but 6551 48 is almost certainly correct as they are repeated on the dial plate. {The "5's" look like "3'" A fairly common dial design and I have a similar one (no movement) with Arabic numerals. The rosette in the centre is mounted on a white enamelled central circle with access to the winding shafts. I have a better photo now. {Attached below}.
Yes I suppose the case could be later. Purpose made - not adapted IMHO.
It seems to be working quite well but early days yet.
Best regards BerryG
