French? mantel clock with rocking gear face.
Discussion in 'General Clock Discussions' started by wlfgrp, May 18, 2017.
  1. I have this mantel clock and I don't find any maker's information on the movement. Both the movement and the pendulum are stamped 14075 and there are a 4 and a 5 stamped on the bottom of the movement. I am thinking a Marti or Freres perhaps. Any advice or hunches sure would be appreciated. I have a large collection from a collector's estate I am trying to get through and this one has me stumped. View attachment 344171
  2. leeinv66
    leeinv66 Super Moderator
    Donor NAWCC Member
    Mar 31, 2005
    7,999
    12
    Industry Specialist
    Launceston Tasmania
    Hi wlfgrp, this is a fairly typical open escapement (rocking gear face) French movement in a nice slate case. These movements were made by the thousands and without a factory mark, it is all but impossible to attribute them to a particular maker. Hopefully, the experts will be along shortly with more information.
  3. George Nelson
    George Nelson Registered User
    Oct 5, 2007
    884
    Tennessee
    Hi, Wlfgrp!
    Welcome to the message boards. You'll find lots of help here, and you are certainly among friends who love to help each other out!
    You're clock is not my area of expertise, but I can tell you that it has what is called a "visible escapement". This includes the small rotating gear which is called an 'escape wheel' and the rocking piece you refer to, which is actually called a 'verge'. The clock appears to be a very good quality example and worthy of conservation and collection.
    It has what I believe to be a slate and marble case (others may know better), and is likely quite heavy. Please, never pick it up by its top only, as the stone pieces were put together with plaster-of-Paris, which dries out and becomes quite brittle over the years. Picking it up from the top only invites a disastrous fall to the floor, and all of the resulting damage that you can imagine!
    Others will be along to comment on the maker and date, if it can be determined. In the meantime, I'm guessing around 1880-1910 vintage.
    Hope this helps just a little!
    All my best, and WELCOME,
    George Nelson
    Ahhh... I see that Peter was posting as I was typing away... He often beats me to the punch!
  4. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    1,862
    watchmaker
    Western NSW, Australia
    The escapement is known as a Brocot escapement.
  5. dAz57
    dAz57 Registered User
    Dec 7, 2011
    1,880
    7
    watchmaker
    sydney Australia
    Actually it should be called a visible escapement, brocot is the type of escapement used here which is also used between the plates in some French movements, generally with steel pallets.
  6. leeinv66
    Donor NAWCC Member
    Mar 31, 2005
    7,999
    12
    Industry Specialist
    Launceston Tasmania
    Yes, that is right dAz57. I'm not sure why I typed "open" rather than "visible", but the latter is correct. I actually have a Vienna movement that has a between the plates brocot type escapement. It is one of my best time keepers.
  7. roughbarked
    Dec 2, 2016
    1,862
    watchmaker
    well a visble brocot then. ;) Yes, they are very good timekeepers.
  8. jmclaugh
    jmclaugh Registered User
    Jun 1, 2006
    3,613
    Devon
    A nice French marble clock with a pendule de Paris movement with an often seen combination of a Brocot suspension adjustment and visible Brocot escapement. As has been said with no makers' mark identifying one is nigh on impossible as they were produced by quite a number of makers and are a pretty standardised movement. The 4 5 is the pendulum length in French inches, i.e. 4 and 5/12.
Similar Threads - French mantel clock Forum Date
Wood mantel clock garniture set, is it French late 19th c.? General Clock Discussions Oct 28, 2016
French mantel clock General Clock Discussions May 24, 2016
Dating a Le Roy French Antique Mantel clock late 18th - 19th Century? General Clock Discussions May 18, 2016
A French mantel clock General Clock Discussions Oct 30, 2015
Is this a French visible escapement mantel clock dated 1875? General Clock Discussions Oct 20, 2013
