French Clock Restoration
JTD
Sep 27, 2005
10,714
1,416
Great work! Please could you explain what method you used?
JTD
macaw
Jul 23, 2014
657
20
Minnesota
I do brush electroplating. To get the effect that I wanted for this clock I used a soft gold solution and kept going over it many many times, and used a lot of gold. The original gold on these clocks test as 10 to 14K, the gold I use is 24K and shouldn't tarnish. I should note that many of these clocks that looked like they've had the gold washed off of them just need a proper disassembly and ultrasonic cleaning to bring the gold back to life.
agemo
Apr 5, 2011
573
596
93
72
SAINT-NAZAIRE - FRANCE
Hi,
I have a question, it's bronze or régule (tin or lead and antimony alloys).
Because I'm amazed by this broken part, bronze does not break.
Amicalement GG
jmclaugh
Jun 1, 2006
5,724
397
Devon
Thanks for sharing. A lovely clock, pics of the movement would be nice to see.
I'm no expert on metals but surely they can all break.
macaw
Jul 23, 2014
657
20
Minnesota
I would call it spelter. The gray mass that was holding one of the breaks together was jb weld. I removed it and used solder as well as drilling small holes through the parts to add wire for support, then filled the cracked still showing with more solder so I could plate over it.
This one was a count wheel bell strike, and I believe it was from Japy. It's now back with its owner so I'm unable to take pics.
agemo
Apr 5, 2011
573
596
93
72
@macaw Thank you I did not know this alloy, which was probably cheaper than bronze.
Amicalement GG
177,601
1,556,523
53,629
nicobirdie
909
3,058
Watch Inspectors by Kent
