Thanks Chris. I did see a bit of debris of sorts on some of the wheels, and pinion and pivot on at least one of them looked a bit rough. Not as worn as what I've seen in videos, but not perfectly polished, to be sure. That said, I am looking at them under a 3X zoomed 15x eyepiece setup, so perhaps they won't look as perfect?
I'm going to run the wheels and bridge through the US again after pegging out the jewels. Truth be told, I am a bit afraid of pegging those jewels, as you can't easily remove the cap jewels and I don't want a piece of pegwood breaking off in there. I'll clean things again and take another look under the higher magnification. Thanks again, as always. Cheers.
*Update: Question: I'm not sure what you're referring to with the plastic washer on the sweep wheel. I know there's an extra shoulder/part on the third wheel that sets down against that spring. If that's what you're talking about, it looks OK to my eye. Thanks.
