Free programm for pendulum (clock) adjustment and calculation
Discussion in 'General Clock Discussions' started by praezis, May 18, 2016.
  1. praezis
    praezis Registered User
    Feb 11, 2008
    465
    27
    Germany
    When setting a clock, one wonders how much of the pendulum length needs to be changed to correct a certain deviation.
    You can:
    - Try (inaccurate, takes several days)
    - Calculate (search for the formula, use math etc)
    - Look up a table (search for a table, still math necessary for the pitch)
    The attached Windows app PENDULUM makes it easy. It directly shows how many rotations of the pendulum nut are needed to remove the entered deviation.
    If the beat rate of the clock is unknown, you can easily determine it, too.
    Instead of turning the rating nut, a pendulum can be adjusted by a weight on its rod. The amount of weight can be determined with this app, for default and also different positions.
    In addition, calculation of pendulum length, beat rate, oscillation period is supplied.
    Initially I wrote the app in German, now English language was added. It will start with your language, else select in the menu bar.
    Program and help files are attached as compressed .zip file. Nothing has to be installed, extract and place the files in any folder and simply click the .exe.
    Hope, you enjoy this little tool.
    Frank
    View attachment Pendulum.zip
  2. scottmiami
    scottmiami Registered User
    May 14, 2014
    608
    Very cool, thanks for sharing!
  3. shutterbug
    43,465
    1,236
    Thanks for that, Frank. When I tried to run it, my computer flagged it as a potential problem since the author is unknown. I ran it anyway, and it runs without issues.
  4. Rockin Ronnie
    Rockin Ronnie Registered User
    Nov 18, 2012
    1,575
    121
    retired educator
    Greenfield, Nova Scotia
    Ran well for me. Handy!
    Ron
  5. Dave T
    Dave T Registered User
    Dec 8, 2011
    3,118
    110
    retired
    NC
    Thanks Frank!
  6. Kevin W.
    Kevin W. Registered User
    22,452
    368
    I am computer illiterate, can this be saved for future use.
  7. shutterbug
    43,465
    1,236
    Yes. Click on the link and click the "save" option. The file will download to your download folder. If you can see it downloading, you should be able to just open that folder. If not, use search to look for the file. When you find the file, right click it, and "extract" the files. When that is done, you can move them to their own folder wherever you want them.
  8. Dave T
    Dec 8, 2011
    3,118
    110
    retired
    NC
    Is anyone still using this app?
