Franz Vosseler 30 day
Darrmann39
Dec 6, 2020
1,185
390
56
Got this Franz Vosseler lunar 30 day anniversary torsion clock under glass dome. Needs a good servicing but should run from what I see
20221008_154131.jpg 20221008_154138.jpg 20221008_154145.jpg 20221008_154155.jpg
KurtinSA
Nov 24, 2014
6,127
711
San Antonio, TX
etmb61
Oct 25, 2010
3,409
563
Mascoutah, IL
What's the pink stuff?
Seems to be a bandaid Lol important part is all the original suspension parts are there
This is what the original fork looks like. It's really a loop with a hole at the end for the spring and a taper pin. That would explain the band aid.
Eric
Darrmann39
Dec 6, 2020
1,185
390
56
I made what was on it when I got it. A very thin piece of brass wrapped around the original to when I got it small end of tapered pin. Putting it over suspension spring and pin it. Just like upper and lower block.
PeterSincak
New User
Nov 1, 2021
Darrmann39
Dec 6, 2020
1,185
390
56
How did you clean a dial ? I am scary to clean and to loose numbers. I am missing upper block - I need to fig. out something - I do not think so that I can find similar to buy. Peter
I didn't do much to dial was in nice shape when I got it. But the numbers are rubbed off a bit by someone. I'd try not to touch the numbers
Staff online
183,900
1,606,205
55,936
juanmasubbie
3,190
Watch case by Kent
Top Bottom
