Francis Abbott Double Fusee
Discussion in 'Your Newest Clock Acquisition' started by LiamJ, Aug 12, 2017.
  1. LiamJ
    LiamJ Registered User
    Sep 25, 2011
    176
    Laxey
    My newest acquisition today was this enormous Double Fusee Bracket Clock by Francis Abbott of Derby. It measures a huge 26'' to the top of the pineapple making it the tallest bracket clock in my collection.
    The case is inlayed with brass and has burl mahogany veneers.
    I have done a little research on Francis Abbott and he certainly had a varied life! Born in 1799 he apprenticed as a clock maker. In the early 1830s he set up his own business in Derby. Shortly afterwards he moved to Manchester and I believe he traded from No.50 Market Street.
    The link below gives a fascinating insight into the varied life Francis had and the important contributions he made to astronomy in later life.
    https://books.google.im/books?id=XoeiJxMmXZ8C&pg=PA135&lpg=PA135&dq=francis+abbott+derby&source=bl&ots=-7jxGFskOS&sig=ZLAHEP23T2FVLz_P2FxihOZEbVc&hl=en&sa=X&redir_esc=y#v:^nepage&q=francis%20abbott%20derby&f=false
    I hope you enjoy the above article and the pictures of this remarkable piece of history.
  2. novicetimekeeper
    Jul 26, 2015
    4,819
    Dorset
    I like the signature on the movement. Most 18th and 19th century bracket clocks seem to be around half a metre high, the smaller ones usually go at a premium.
  3. LiamJ
    Sep 25, 2011
    176
    Laxey
    Thanks Nick, yes the signature is rarther nice and ornate. All five of the pillars are also mounded and engraved with simple detailing.
  4. DeanT
    DeanT Registered User
    Mar 22, 2009
    491
    Nice clock.
    How long is the pendulum? If the clock is 26 inches high the pendulum must be longer than normal?
  5. LiamJ
    Sep 25, 2011
    176
    Laxey
    The pendulum is quite long Dean, it measures 17" in total from the bottom of the bob to the top of the suspension spring.
  6. P.Hageman
    P.Hageman Registered User
    Jul 20, 2014
    387
    The Netherlands
    This clock shouts out QUALITY, like it very much. Congrats!
  7. LiamJ
    Sep 25, 2011
    176
    Laxey
    Thank you all. Sadly there is one small problem. The hinge was only stuck onto the bezel with some kind of resin. For safety I have taken it off as I didn't want it to fall off!! Are hinges usually silver soldered onto the bezel surrounds?
  8. novicetimekeeper
    Jul 26, 2015
    4,819
    Dorset
    I don't know, but I would guess riveted on spun bezels, probably cast on cast bezels. Somebody will have worked on a few of that age.
  9. jmclaugh
    jmclaugh Registered User
    Jun 1, 2006
    3,613
    Devon
    Congrats, a beautiful clock.
  10. P.Hageman
    Jul 20, 2014
    387
    The Netherlands
    Yep, seen several which were original soft soldered to the spun bezel. The reason for using resin ( which I also did when necessary) was not to heat up the bezel with the risk of damaging the old glass.
  11. LiamJ
    Sep 25, 2011
    176
    Laxey
    Thank you, that would make sense then. The glass in the bezel is original so I definitely don't want to damage it. I take it there is no easy way of removing the glass to carry out the fix?
  12. P.Hageman
    Jul 20, 2014
    387
    The Netherlands
    If so, I would be happy to hear.
Similar Threads - Francis Abbott Double Forum Date
C. Jerome. New-Haven. Double Fusee Your Newest Clock Acquisition May 21, 2017
Double Fusee, can anyone help with the makers name? Approx Date? Your Newest Clock Acquisition May 4, 2017
J.COLEMAN of London double Fusee Your Newest Clock Acquisition Apr 15, 2017
E. Howard brass double faced depot/corridor clock Your Newest Clock Acquisition Dec 26, 2016
