Frances Rubie Watch Info
Discussion in 'American Pocket Watches' started by ironwood, Feb 3, 2007.
  1. ironwood
    ironwood Registered User
    Sep 12, 2006
    92
    Hi, ironwood again. I also just aquired this 10 size Frances Rubie. I would appreciate any info anyone may know about this watch. Serial # 50357. It is one of the nicest movements I have found to date. In a beautiful case marked only with two stars. Thanks in advance for any help. ironwoodhttp://www.reddogdesign.com/auction/rubie.jpg
  2. John F
    John F Registered User
    Sep 28, 2001
    919
    Sweet watch - first run Frances Rubie. Looks to be in very nice condition. It should date from 1868. Not a heckuva lot of these made.
  3. ironwood
    Sep 12, 2006
    92
    John, Thanks for your reply. It is a beautiful watch. How many were made in the first run? What do you make of the two stars on the case side by side like ** ? Thanks again.
  4. John F
    Sep 28, 2001
    919
    I believe there were just 3 runs of Grade 23, each run was 1000 movements, for a total of 3000.
    No idea on the case markings. If you could post a picture, someone might recognize it.
  5. ironwood
    Sep 12, 2006
    92
    Here is a picture of the mark on the hunter case. It is just two stars side by side. It is marked on the inside front and also the same mark on the inside rear of the case. Has anyone ever seen this mark before? Thanks again for the info.
  6. Tom McIntyre
    Tom McIntyre Technical Admin
    Aug 24, 2000
    83,058
    1,725
    176
    retired SW dev
    Boston
    I believe only the first run of Frances Rubie was actually produced. There is an extensive discussion of this strange grade on the Elginwatches web site.
    The name was also used on some Grade 201 movements around the turn of the century.
  7. Jerry Treiman
    Jerry Treiman Registered User
    Aug 25, 2000
    6,412
    1,912
    Geologist - California Geological Survey
    Los Angeles, CA
    Ironwood - does your Francis Rubie have a timekeeping problem? I notice that it has a replacement regulator with the pins in the wrong position (assuming that Tom's is correct). If it is not keeping time, a proper regulator should be found rather than adjusting the timing of the balance. I expect a regulator from one of the lower-grade examples could be used.
  8. ironwood
    Sep 12, 2006
    92
    No problem with timekeeping. Do we know which is the correct regulator? Thanks for the help. ironwood
  9. Jerry Treiman
    Aug 25, 2000
    6,412
    1,912
    Los Angeles, CA
    Judging from the degree of finish on Tom's example I would think that is the correct regulator for a higher grade movement. Also, the regulator pins are usually closer to the hairspring stud than on yours.
