Four hole square collet wrench for tapping small threads
Discussion in 'Horological Tools' started by THTanner, Feb 2, 2019.
  1. THTanner
    THTanner Registered User
    NAWCC Member Donor
    Jul 3, 2016
    2,648
    198
    Carson City, Nevada
    I chanced upon this vintage four square hole collet wrench for tapping small threads. Overall it is 3 inches long. You loosen the thumb screw and slip the tap into the proper size square and tighten the screw. Works well with the sub 2 mm taps
  2. John MacArthur
    Feb 13, 2007
    352
    29
    TH - Are you sure that is not a tiny adjustable die set? I have one that appears identical, and it has what looks like die threads in the little holes.
    Johnny
  3. THTanner
    NAWCC Member Donor
    Jul 3, 2016
    2,648
    198
    Carson City, Nevada
    I suspect you could be correct about what this was originally - and I was wondering the same - but the square holes in this one have no sign of threads at this time and it came with some taps that fit - perhaps a well abused adjustable die set that ended up a tap wrench instead of the die for the set.
  4. John MacArthur
    Feb 13, 2007
    352
    29
    I'll try to get a closeup of mine to post. I've never seen another like it.
    Johnny
  5. John MacArthur
    Feb 13, 2007
    352
    29
    Here are pics of mine:
    FWIW, I've never used it - It never fit anything I needed to match, and I have too many more modern taps and dies, both larger and smaller.
    Johnny
    THTanner likes this.
  6. THTanner
    NAWCC Member Donor
    Jul 3, 2016
    2,648
    198
    Carson City, Nevada
    Nice - same item - thanks for the clarification - The square holes in mine are either totally worn from use and abuse or perhaps simply filed out to be a good square to hold the taps with no wiggle. It was probably a complete set of taps and dyes when new and only the taps survived. When I picked it up the three taps were in place in the square holes
    It works great as a tap wrench now ;)
  7. John MacArthur
    Feb 13, 2007
    352
    29
    I never had any taps, only the adjustable die shown. If anybody has ever used one of these, please speak up and let us know how it worked.
    Johnny
