Dieter, thanks very much for posting your clocks. Following is the info I can provide regarding confirmation of date made, back plate info, and other details:
First Clock:
Back Plate 1149, Serial number 676
- This clock was made in 1926 following the takeover of GB by Gebrüder Junghans. At that time the following happened:
1) The Gustav Becker circular logo and Medaille d'Or stamp were no longer used, either for the 400-Day or any other GB clock. It appears that in the negotiations with Junghans the only trademarks that were permitted to be carried forward were the name "Gustav Becker" and the GB anchor logo. Those are the only marks I have been able to document on any GB logo clock made after 1925.
2) The previous GB serial number series which was started about 1850 in the Freiburg factory and applied chronologically to all clocks made by Becker at that factory (except for "American" design movements) was discontinued. The highest number recorded so far in that series is 2508167, likely completed at the end of 1925 or very early 1926. The separate number series that was started for GB clocks made in the Braunau factory was also discontinued.
3) A new serial number series was started for 400-Day clocks (apparently from serial number "1"), and parallel new number series started for other types of clocks. As of this writing I have found separate series numbers applying to (a) 400-Day Clocks, (b) Westminster Chime clocks, (c) Weight driven wall clocks, (d) Weight driven grandfather clocks. The reason I know this to be fact is that I have documented several duplicate serial numbers between the different type movements.
The lowest serial number documented to date for the 400-Day series made from 1926-1932 is 16, the highest 4990, most likely made just before the Freiburg factory was closed in late 1932 and all Gustav Becker design clock movement production stopped. After this happened, all production was moved to Schramburg and GB logos were applied to movement designs from Junghans and HAC; however no more 400-Day clocks were made.
Second Clock:
Back Plate 1199, Serial number 2205654
- Based on the serial number this clock would have been made about mid-1911. However, GB introduced pallet inspection holes in early 1909 and by mid-1909 no more clocks with Plate 1199 have been found, at least until now. Starting from serial number 2107726 every clock in my data until now has the pallet inspection holes. I suspect the serial number on your clock may have been transposed, as it falls in the middle of a series of Vienna style wall clocks. It will be appreciated if you could verify the number, I suspect it should be something like 2025654 which would have been made in first half 1908.
Third Clock:
Back Plate 1206B, Serial number 2465124
- This clock was made about mid-1924 based on the serial number. There are several features that bear noting:
1) The 4-Ball pendulum is the first Becker design introduced in late 1915, very difficult to regulate because you have to loosen a set screw, make the adjustment, re-tighten the screw and the check the timing. A second design was introduced in 1926 that is much easier to regulate.
2) The base has a brass-plated steel cap over the center. This feature was actually started in the first year of production of GB clocks, and appears on about half of all the glass dome models. The same feature was used by nearly all the other makers of 400-Day clocks from 1903 until the 1930's.
3) The flared base design and the crown design were first noted in early 1906 and continued to be used until 1932, although not always together on the same clock.
Fourth Clock:
Back Plate 1201(?), Serial number 1910765
- This is an earlier clock, made about second quarter 1906. I think it has Plate 1199, unless the words "Made in Germany" aren't visible in the photo as would be there for Plate 1201. The features of interest on this clock include:
1) The crown with cast finials was first noted in 1905 and continued in use until 1912. None have been documented after that year.
2) The pendulum is the second version of GB's 6-post gallery disc pendulum design. There were a total of seven versions, the first being the "fanciest" and each one following more simple and less expensive to make. The GB disc was used from the beginning of production of their standard size Graham escapement models in 1902 until the end of production in 1932.
3) The suspension guard that you pointed out is the first version introduced by GB in 1905. This design with the top bent forward continued to be used until 1909, when it was replaced with the more simple one having a rounded top as seen on the other clocks you have posted. This coincided with the introduction of upper suspension bracket No. 7. That bracket did not have adequate space underneath to allow the bent-over top that had been used until that time.
These are very interesting clocks and a nice selection covering the time from early production until after the Junghans takeover. One question: Do the disc pendulums have matching serial numbers on the bottom of the disc? That will be good to know for documentation.
