I just got this clock from a second hand store and it has a fabric elecrical cord and it still works! I just wanted to know some information about it so I know what kind of clock I have.
As Eskmill says your version of this clock was called the "houseburner" due to a design fault. What would happen is that the contact could "freeze" at the instant of contact, making a continuous circuit which would overheat the transformers. There was no thermal cutoff in the circuit so the transformers would catch fire or get hot enough to set fire to any cloth or wood surface underneath the clock. That version was produced for less than a year when the fire reports started coming in, so they redesigned to run on three "D" cell batteries which could not produce enough current to create the heat required to start a fire.
I have one of the later ones with the original battery installation, shown here:
This model has a working moon phase dial and also a passing strike on the hour. The Bell is the silver cylindrical piece mounted near the bottom of the movement back, just above the balance. It's difficult to hear it more than a few feet away when the glass dome is in place. Not shown in the photos, the bottom cover is a resin impregnated brown fiber sheet cut to fit and held in place with three screws. There are no feet or leveling device; the base sits flush to the support surface.
The clock works on the same principle as a Eureka, having an electromagnetic coil inside the balance wheel and a flat steel stator fixed to the movement frame. The contact switch is a kind of gravity lever device (I don't have a photo) that contacts as the balance wheel is rotating clockwise (seen from the front) and then falls over so it passes the contact point on the return rotation. I can see that if this lever were to stick in position and not miss on the return it could jam on the contact and that would cause the continuous circuit that destroyed many of the early versions.
Regulation of the clock is the same as a Eureka, with a large hairspring at the back of the balance and a rating arm that changes the effective length of the spring to speed up or slow down the clock.
