Hi, This FMS movement continues to strike and does not stop. I can see that the last tooth on the rack is smaller than the rest and does not allow the gathering pallet (?) to advance to the last tooth on the rack. I have also been adjusting the spring tension on the rack (last picture) with occasional but not lasting success. What would be the correct fix to this problem.
Thank you so much,
Jerry
Thank you so much,
Jerry
