Flakig Dial-Dusty-How To Clean?
Discussion in 'Clock Repair' started by popeye, Jul 17, 2017.
  1. popeye
    popeye Registered User
    May 8, 2005
    1,459
    36
    I I bought a clock that had no glass in bezel. It is flaking in areas and the dial is dirty/dusty. Any recommendations on how to clean it?
    It is dusty-curious how to clean or remove dirt.Thanks.
  2. Willie X
    Willie X Registered User
    8,143
    32
    The choices are pretty much: to enjoy it like it is, or have it restored.
  3. shutterbug
    shutterbug Super Moderator
    34,643
    44
    You could try a very soft paint brush to remove some of the dirt, but if the dial is flaking some of that will come off too.
  4. klokwiz
    klokwiz Registered User
    NAWCC Member Donor
    Feb 4, 2009
    1,043
    WRENCH
    Annapolis, MD
    #4 klokwiz, Jul 17, 2017
    popeye,
    it depends, what is the dial made of? Since you said it has bezel with no glass it is likely a mantel type clock. Most have paper dials, others ceramic fired dials.
    first step would be to lightly brush dial with a soft horsehair brush, this will lift any loose dirt from dial regardless what type.. As was mentioned if the dial is coming apart you will lose some dial so be careful. Best thing is to go slow and keep an eye (popeye) on what is coming off.
    If the dial is paper the best approach is to brush off dirt. do not brush it in but brush to lift dirt off surface. There are commercial paper cleaners you can use but only after brushing.
    if your dial is ceramic, brush it first. then try a little water to clean any spots. taking care not to rub hard and to be sure that any print or numbering is not being removed. some dials have unfired ink numbering, very delicate.
    If your dial is silver colored it may be silvered and will be damaged by any abrasive or cleaner. bush it and only use water on any spots to see if they will lift. gently with a q-tip
    Joe
  5. JTD
    JTD Registered User
    Sep 27, 2005
    4,051
    23
    Maybe I misunderstood, but I thought the OP meant that the glass was missing, not that there never was glass in the bezel.
    But as I said, perhaps I misunderstood.
    JTD
  6. popeye
    May 8, 2005
    1,459
    36
    thanks all
  7. klokwiz
    NAWCC Member Donor
    Feb 4, 2009
    1,043
    WRENCH
    Annapolis, MD
    popeye,
    what no feedback , no photos?? call me, sometime??
    Joe
Similar Threads - Flakig Dial Dusty Forum Date
Paper dial replacement tutorial Clock Repair Saturday at 5:44 PM
Emperor/Jauch P110 moon phase dial mechanism help Clock Repair Nov 2, 2017
Ansonia Dial Swap-Has anyone done this one? Clock Repair Oct 29, 2017
Pearl Grandfather 451-050H with Moon Dial Clock Repair Oct 26, 2017
Dusty Movement Clock Repair Apr 28, 2012
