Featured
- #1
Hi, I've a 2 piece ornate and engraved pocketwatch from my late father's estate. It's medium size and has roman numerals on a white face and single crystal glass. The large stem is not for turning but rather for depressing (aprox 7 mm) to activate something, and when I do it sounds like it's winding a spring or spinning something inside. Once I remove the watch from the gold outer case, there is a square keyhole on the rear of the inner case, probably to wind? Then when I open up the inner case, on the backside is a small silver half-moon dial with single digit numbers and another smaller square keyhole for this mechanism. There are 3 letter & 2 ? hallmarks on the inside of the outer case. The back of the watch mechanism is where it's engraved in cursive writing: 2014 Fladgate, London and below is a half-blue spring-steel clip that appears to hold the guts in place. I've NOT opened that portion up for further investigation.
Here's the link to several photos of my watch, click on them individually to enlarge: http://s17.photobucket.com/albums/b72/gocargo/pocketwatch/
Where would I go to have this serviced, obtain operating instructions and to buy (or to have made) the winding keys?
Thank you in advance!
