The wheel on the arbor of the first wheel has become loose. What is the best way to attach the wheel to the arbor ?
Lets be clear what the problem is. If the wheel is wobbly and loose on the hub, do what Willie said and positively DO NOT USE LOCTITE or you will never be able to wind the clock. If the brass hub is loose on the steel arbor then we really need to see the part to determine how the hub was originally attached. Some (E. Ingraham for example) use a pin that can shear off. Others press the hub onto a spline.Normally the wheel is held to the hub with a cupped washer which is staked to a light friction fit between the wheel and the hub. If the wheel is floppy all you need to do is increase the old staking slightly. Make a staking punch that matches the old marks. Support the hub on an anvil with the proper size hole. Do one light tap on each point (usually there are 4). Repeat as necessary until you get a little friction and no wobble.
I'm afraid that we (at least me) don't understand just what you are describing. I've never seen a 400-day clock with a wheel that has 10 spokes, or spokes "on the outside of the wheel"? The first wheel (sometimes called the 'great wheel') is the wheel (gear) with no spokes that has the barrel that contains the main spring and winding arbor. That wheel drives the pinion (small gear) that's on the arbor (axle) that has the second wheel (large gear that usually has 4 spokes). The pinions are the small (usually steel) 'gears' that are made as part of the arbor (axle). The "wheels" are the larger brass gears. The train of wheels and pinions ends at the top of the movement with the 'escape wheel' which is the smaller brass wheel with teeth that have a distinctively different shape.Thanks for all suggestions. This is a 400 day clock. Staking seems like the way to go. I do not know how to post pictures; however, the wheel is pressed on to the arbor with @ 10 spokes on the outside of the wheel. I have several degrees of wobble on the arbor. Explain the staking technique, please.
Whatever, If things have come loose this end, there should most likely be more serious damage further entrain.Forget the staking and follow RC's instruction. I have never seen a loose 1st wheel on a 400 day clock.
The first wheel contains the spring. Maybe you are speaking of the 2nd wheel?
Sounds likely. This is usually a visible loose screw and cock, however.Are you, perhaps, referring to the ratchet that has the click on the outside of the drum that has the winding arbor?
Some have the click wheel inside the plate but I can't see it coming loose there.
Anyway, if the square is sloppy, though it can be temporarily fixed, this is a dangerous part of the clock to make mistakes in. If a ratchet wheel or click wheel, these are inexpensive fixes for something that could cost a whole lot more.
To all concerned who seem to be confused about the nomenclature of a 400-Day clock, refer to the exploded clock views in the Appendix of the Horolover Repair Guide. The Mainspring Barrel is "NOT" the first wheel, but is the mainspring barrel. The FIRST WHEEL is the first arbor with a gear that is driven by the mainspring barrel gear. Second, third etc, 4th wheel is the center (minute) wheel.Sounds likely. This is usually a visible loose screw and cock, however.
The problem is that the OP seems to refuse to reply to the thread
or post a picture of what he is talking about.
The the pinion on the wheel driven by the main wheel is has 10 leaves.
Since he continues to refuse to reply or post a picture I'd have to say
that maybe he has already fixed his problem and gone on his way.
Yes, but don't lock the door. I believe the OP stated a few posts back that the problem was resolved with Loctite. Would not be surprised if we have to revisit this one in the future. The unanswered question is what caused the problem in the first place. If in deed there was a 'spring release event' it likely will happen again if nothing has been done to prevent that happening.Probably true - time to move on
