First wheel for Elgin 739 movement question.
Discussion in 'Watch Repair' started by doc_fields, Apr 17, 2017.
  1. doc_fields
    doc_fields Registered User
    Sep 29, 2004
    1,123
    Would anyone know if the first wheel from any other Elgin movements fit an Elgin 739 movement? Thanks!...............................doc
  2. GeneJockey
    GeneJockey Registered User
    Mar 2, 2012
    838
    739 isn't a US-built grade number, in fact it's not a grade number Elgin used prior to going out of business. Are you sure it says 739? Could you take a picture?
  3. doc_fields
    Sep 29, 2004
    1,123
    My bad! It's actually a 719 movement, used in a watch with jump hours. Can't take a picture right now, hope this might help............................doc
  4. 18k BPH
    18k BPH Registered User
    Aug 18, 2016
    26
    I am not certain what you mean by First wheel, so below are the part interchangeability lists for Elgin Grade 719:
    [​IMG][​IMG][​IMG][​IMG]
  5. GeneJockey
    Mar 2, 2012
    838
    If you mean CENTER Wheel, the only other Elgins that use the same Center Wheel assembly are the other Direct Reading Elgin grades, the 717 and 721.
    In Elgin parlance, 'Main Wheel' is what others call the Crown Wheel.
  6. Tom Huber
    Tom Huber Registered User
    Dec 9, 2000
    2,732
    7
    I was taught that the "first wheel" is the mainspring barrel. The center wheel is the second wheel in the train.
    Tom
  7. doc_fields
    Sep 29, 2004
    1,123
    Center wheel it is then. I need one. Message me if you have one available. Thanks to all who responded. ........................doc
Similar Threads - wheel Elgin movement Forum Date
American PW Elgin 10 size model 28 need escape wheel teeth straighten Watch Repair Oct 18, 2015
American PW Elgin Veritas 16S Fourth Wheel lower jewel # Watch Repair Aug 24, 2015
American PW Elgin Full Plate Ratchet Wheel Orientation Watch Repair Nov 18, 2014
Elgin Pocket watch Stem setting - winding pinion, Yolk and Clutch Wheel/Stem Assembly Watch Repair Mar 6, 2014
American PW Minute wheel for Elgin 555 movement Watch Repair Dec 18, 2004
