I'm a woodworker and I am building the case for a grandfather clock that will be 80 in tall, 18 in wide, 12 in deep. I'm new to clock movements, etc and I want to make sure I am ordering the right parts and not missing something.
I'm planning on ordering the 1161-853 with auto night shut off. I'll need a 12-rod v-shaped chime block. I want a simpler looking pendulum so I'm wanting a wooden stick pendulum and a brass bob that is 8.5 inches in diameter. As such it looks like I need two 9.9 pound weights and a 7.7 pound weight.
This is where I'm getting confused. For the weights I'm not sure if I just need to order a weight kit with the outer sleeve, the weight filler, and caps or if there is some other part I need between the weight and the cables.
I'm also confused as to the pendulum. I see I can order a brass bob of the right dimension and a wooden 114 cm long rod, but I'm not sure what part connects the pendulum to the movement, if there is a part that goes on the end of the pendulum to help with adjusting the swing frequency, and how the brass bob connect to the wooden rod.
Any help would be appreciated.
chris
chris
