I'm a beginner in horology whose interest is clock making, but I have elected to try a few repairs as a way of familiarising myself with clock mechanisms - a bit of hands-on experience of ready-made examples can't hurt. So, this thread is about my first attempt to repair a clock, and I'd appreciate any pointers, suggestions, etc, as I go along. Feel free to correct any terms that I get wrong - I come from a mechanical engineering background, but not clocks.
The clock is a wall clock, no chimes, no second hand, no makers marks that I can find anywhere. The dial appears to be cardboard and uses conventional numbers rather than Roman. It has a pendulum and a mainspring. The plates on the movement are about 3" x 2.25". The only mark I can find is on one of the plates: "29 cm". Would that be the pendulum length? (Seems close, but I haven't measured the pendulum assembly yet.)
Below are some photos of the movement, and my thoughts so far.
A general overview...
xyzzytom_210547
This is what I was presented with when I took the hands and dial off. The key came with it, and I found that it doesn't wind - the shaft/arbor inside the mainspring rotates okay, and seems to pull the spring around until it gets to a certain point, where there's a click and the spring relaxes again. The outer end of the spring wraps around one of the pillars and looks intact, so it would seem that the mainspring is either broken in the centre, or perhaps has become detached. There was no ratchet clicking when winding, and it's possible to turn the key both ways.
View of the mainspring, click ratchet thingy, and great wheel...
xyzzytom_210548
Here, you can see the ratchet, the click spring, and a hole to the left of that in one of the great wheel spokes. I had a root around in the case, and found a tiny bit of steel that looks like the end of the pivot for the click. No sign of the click itsel or the rest of the pivot.
My guess is that the pivot for the click has snapped and the mainspring has rapidly unwound itself, possibly leading to damage at the centre. Alternatively, perhaps the mainspring damage occurred first, and the click pivot was a casualty of the released force.
I reckon I can make a new click and pivot, but I don't know yet how the mainspring is/was attached to its arbor (and I haven't attempted to dismantle anything - I'm aware that they are dangerous).
The hour wheel...
xyzzytom_210549
Not in perfect condition. I'm pretty sure I can get that straightened out once it's been removed. Note that the pinion that drives it is sitting quite low below the retaining washer/circlip - a lot of endshake there, but I don't know if it's likely to be a problem.
A general view from the side...
xyzzytom_210550
There are 2 solid pinions and 3 lantern pinions. It's also very dirty. I noticed that the oil in the wells at the pivots is more like a dryish green jelly.
A view from the top, showing the escapement and the bit that holds the spring for the pendulum...
xyzzytom_210551
You can see the hour wheel here as well, and the amount of slack in the pinion that drives it. The escapement seems to work if I hang the pendulum and give it a nudge, and the gears immediately following it seem to turn convincingly. Much muckiness to clean up.
xyzzytom_210547
xyzzytom_210548
The hour wheel...
xyzzytom_210549
xyzzytom_210550
xyzzytom_210551
