Finer & Nowland Cylinder movement
Discussion in 'European & Other Pocket Watches' started by Omexa, Sep 22, 2014.
  1. Omexa
    Omexa Registered User
    Feb 28, 2010
    4,991
    625
    Darwin, Australia
    Hi, I recently purchased a movement by "Finer & Nowland", it is in sad condition; Broken Dial caused by the Gold Case being ripped off, a broken Center Arbor and something wrong with the Cylinder Staff. I have another Cylinder movement by "Thomas Walker", London that ticks very nicely; it has a Brass Escape Wheel. The Finer & Nowland appears to have a Steel Escape Wheel. Do these type of Staffs have replaceable Tampons? Regards Ray
      File size:
      216.7 KB
      88
      File size:
      131.8 KB
      68
      File size:
      116.3 KB
      69
      File size:
      85.5 KB
      74
      File size:
      75.7 KB
      72
      File size:
      127.4 KB
      62
      File size:
      95.1 KB
      57
  2. MartyR
    MartyR Registered User
    Dec 16, 2008
    11,045
    305
    UK
    Only the female ones .... :excited:
    Finer & Nowland of London was originally between Thomas Finer and Thomas Nowland. They established a business in 5 Hatton Garden in 1794 and are then listed in the 1808 trade directory as trading at 48 High Holborn, London as jewellers and watch makers. They also appear in the 1822-3 trade directory in the Watch and Clock Makers section at the same address but have added that they are also chronometer makers. The business continued until 1856.
    I think your serial number is 3735? I have found references to three complete pocket watches - #4166 halmarked 1825, #4387 hallmarked 1828 and #4823 hallmarked 1840; those show a very low production volume of maybe 80 per year, which suggests a date of about 1820 for yours - and that looks about right for your movement.
  3. gmorse
    gmorse Registered User
    11,099
    1,493
    Retired from Xerox
    Hi Ray,
    The staffs in English cylinders are different from the Swiss ones. They do have tampons, but the pivots are usually separate and inserted into the tampons in tapers, so rather easier to replace. Do you have access to Gazeley's book on escapements?
  4. Omexa
    Feb 28, 2010
    4,991
    625
    Darwin, Australia
    Hi Martin, the Serial Number is 2735. I found a list of the best Watchmakers supplying Chronometers to the Admiralty. Regards Ray
    zacandy likes this.
  5. Omexa
    Feb 28, 2010
    4,991
    625
    Darwin, Australia
    Hi Graham, I do not have access to Gazely's book. I purchased a number of years ago lots of pivots with taper, all I have to do is find them; at the time of purchase I did not know what they were for but thought that they may come in handy at some stage. Why one Escape Wheel Brass (Thomas Walker) and another Steel (Finer & Nowland)? Would this have to do with what the Cylinder Staff is made of (Ruby or Steel)? Regards Ray
  6. gmorse
    11,099
    1,493
    Retired from Xerox
    Hi Ray,
    The mix of materials was probably down to the preferences of the individual watchmakers; the best English ruby cylinders sometimes had gold escape wheels.
  7. Burkhard Rasch
    Jun 1, 2007
    4,748
    125
    General-and trauma surgeon
    Twistringen
    #7 Burkhard Rasch, Sep 23, 2014
    I´d also be curious about the cylinder material.AFAIk the materials were allways matched one hard with one soft,the hard material reserved for the cylinder itself.So I whish You luck,maybe it's a ruby cylinder!
    Best
    Burkhard
  8. MartyR
    Dec 16, 2008
    11,045
    305
    UK
    The serial number would suggest a much earlier date, but it now becomes obvious that Finer & Nowland must have made many more watches in the earlier years than the 1825-40 period covered by the numbers I quoted. I wouldn't put your movement earlier than 1810, and I still suspect that 1820 is closer :)
    That Admiralty document is a great find! I don't think it's a list of suppliers to the Admiralty; I believe it's a list compiled by the Admiralty of chronometers submitted to Kew Observatory for testing, and I think it's maybe a potential shopping list for the Admiralty. Teir Lordships seem to be checking that the chronometers are submitted by the makers themselves before they make a buying decision! It says a lot about how the Admiralty operated in terms of buying chronometers, and it adds a lot of weight to the authorship of those. I notice three of the big names of the time in the document - Charles Frodsham, Parkinson & Frodsham, Arnold & Dent - and I'm surprised to see John Frodsham there (I didn't know he had submitted to Kew). Apart from those and Thomas Hewitt, I don't know the others.
    Right at the bottom there is an interesting name - Roskell & Bishop (?) - which Dave might find on his travels around the Roskell family :)
    Where did you find the document? The complete ledger could provide a walth of research material!
  9. Omexa
    Feb 28, 2010
    4,991
    625
    Darwin, Australia
  10. Allan C. Purcell
    Feb 9, 2013
    2,274
    776
    retired
    Germany
    Hi Ray- Well over three years old this thread, but for me good news. I have been having a few problems trying to find out more on this firm, but of course great fun. I thought if I put a few of the interesting bits on this thread more people would look at it and hopefully send in the numbered Finer & Nowland details.Best Allan.
    IMG_4684 (2).JPG IMG_4685 (2).JPG IMG_4686 (2).JPG IMG_4687 (2).JPG IMG_4683 (1).JPG
  11. Allan C. Purcell
    Feb 9, 2013
    2,274
    776
    retired
    Germany
    [​IMG] Thought this might help.Allan.
  12. Allan C. Purcell
    Feb 9, 2013
    2,274
    776
    retired
    Germany
    I noticed above Martin your remark on Roskell & Bishop. I left it out of the above because I could not read it, plus I think we would have found the firm Roskell & Bishop by now? So I went back to the original document, and this is what it says.
    Roskell 8, Bishop 2, Goff 1, Norris 1, eiffe 1, Munster is 900.
    Why this note is written there leaves plenty of room for speculation- it could be they were late entries, or disgarded?? Hope you find this has interesting has I do, pity the numbers were not given except for Munster. Best Allan.
  13. Allan C. Purcell
    Feb 9, 2013
    2,274
    776
    retired
    Germany
    Did you press that button again??
