Finally, a Seth Thomas Regulator #2
Discussion in 'Your Newest Clock Acquisition' started by Rockin Ronnie, Oct 14, 2018.
  1. Rockin Ronnie
    Rockin Ronnie Registered User
    Nov 18, 2012
    1,444
    86
    retired educator
    Greenfield, Nova Scotia
    Picked up my Seth Thomas Regulator #2 in mahogany. According to the identification chart from Clockguy the clock was made between 1922 and 1929. It is unmarked except for the 77A stamp and the letter "K" stamped underneath it. Is K a production month/year?
    The case is in very good shape with no veneer loss although the finish has lost its lustre. It is missing the label. The face has minor losses but is in good condition.
    The clock runs well but only with the hands off. Must be an issue with clearance between the minute and hour hands, otherwise, I am running it for a few days to see if there any other underlying issues.
    Ron
    RS ST2_8.jpg RS A Tick in Tyme (6).jpg RS putting stuff away (16).JPG ST2_5.jpg
    Dave T likes this.
  2. brian fisher
    brian fisher Registered User
    Jan 20, 2017
    1,298
    276
    houston, tx
    fantastic! we are now both in the club. I would assume that clocks like this are not easy to come by in your neck of the world. it actually seems to be from the same era as the one I found last week. in my opinion, mahogany is superior to oak
    you can get a reproduction label from the Timesavers catalog if you wish. have you checked to see if the movement is in beat? whatever ails it, I am sure you will figure it out.
    Rockin Ronnie likes this.
  3. Jim Andrews
    Jim Andrews Registered User
    Oct 11, 2018
    155
    IT Administrator
    Oklahoma panhandle
    great find! The dial is in nice condition and looks to be original. I have one just like this and an older one in oak with the "castle" bottom. You'll enjoy it once you get it dialed in.
  4. Uhralt
    Uhralt Registered User
    3,841
    379
    How much amplitude do you have on the beat plate? 1.5 on both sides or more should be good.
  5. Rockin Ronnie
    Nov 18, 2012
    1,444
    86
    retired educator
    I have a little over 1.7
    Ron
  6. Rockin Ronnie
    Nov 18, 2012
    1,444
    86
    retired educator
    Not too difficult to find. Thanks for the reproduction label suggestion. Since it appears to be a larger label for that clock does it go behind or inside?
  7. Uhralt
    3,841
    379
    The label goes to the bottom inside. The one available at timesavers is not identical to what I have in my #2 from 1880 to 1896.
  8. Uhralt
    3,841
    379
    With an amplitude of 1.7 it should run ok with or without hands. Have you serviced yours already? After servicing (polishing pivots and the anchor mainly) mine runs around 1.9 to 2.
  9. Rockin Ronnie
    Nov 18, 2012
    1,444
    86
    retired educator
    Not serviced as yet but plan to shortly. Yes, it seems to run strong.
    Ron
  10. sylvester12
    sylvester12 Registered User
    Oct 17, 2015
    563
    69
    Nice looking clock, looking at the picture it looks like the winding arbor is shifted to the left. The hour or second hand could be binding on the side of the dial.
  11. Rockin Ronnie
    Nov 18, 2012
    1,444
    86
    retired educator
    Actually, I saw this somewhere," Hands rubbing on the dial is indeed a big problem with ST #2's Sometimes
    the wooden crossbar which supports the center of the flimsy metal dial
    has been removed to get at the movement and not replaced. If the seconds
    hand rubs (at all) the clock stops."
    Could be the problem.
  12. Uhralt
    3,841
    379
    Or the screw that attaches the dial to the center crossbar might be missing.
  13. sylvester12
    Oct 17, 2015
    563
    69
    The second hand rubbing will stop the clock. When I got my ST #2 the guy gave me a replacement dial so I could put the original away in a safe place and the second hand was rubbing and kept stopping it.
  14. River rat
    River rat Registered User
    Apr 4, 2009
    559
    106
    Congrats mine about the same model and made about the same year but made of oak.
  15. Kevin W.
    Kevin W. Registered User
    21,664
    213
    Nice clock Ron. Mine is Mahogany too. Mine has less swing but keeps running fine and its a great time keeper.
  16. Rockin Ronnie
    Nov 18, 2012
    1,444
    86
    retired educator
    There are two screws and both are there. Second hand rubbing could be the culprit.
    Ron
  17. Rockin Ronnie
    Nov 18, 2012
    1,444
    86
    retired educator
    Fixed. Minute hand was rubbing against the hour hand. Pushed the hour hand in further allowing clearance with the second hand. Thanks all.
    Ron
  18. woodlawndon
    woodlawndon Registered User
    Jan 18, 2017
    607
    119
    Woodlawn, Ontario
    Nice one Ron! I'm still on the look-out for one of these, they pop up occasionally around here but the sellers seem to want fairly serious coin, and they're getting it too.
    Don
