Fhs 261-080
Discussion in 'Clock Repair' started by KLS, Mar 5, 2015.
  1. KLS
    KLS Registered User
    Apr 18, 2014
    64
    Technician breathing apparatus & personal gasdetec
    Netherlands
    Hi,
    I am taking my first Mvmt apart.
    It's a Franz Hermle 261-080 with number 125-780 with PL = 31 cm.
    Can anyone expl. the number?
    I will take pictures from every step.. But it's a hobby, and takes probably some weeks.
    Be patience please
    Open for suggestions
  2. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    154
    deceased
    Hi, Klaas. Your Hermle movement was made in 1971, and has a beat per minute of 125.780, with a 31 cm pendulum length. First step, let down the mainsprings before taking it apart.
  3. Randy Beckett
    Randy Beckett Registered User
    May 23, 2012
    2,555
    23
    33 yr. employee of American Electric Power Company
    Mt. Pleasant, Tx
    Looks like it's weight driven. Strange puppy with that short a pendulum, unless it's for a cuckoo.
  4. harold bain
    40,850
    154
    deceased
    Quite right, Randy, good catch. Should have looked closer, just finished repairing a broken ratchet on a similar movement, in a Zaandam clock. Fun job that was.
  5. MARK A. BUTTERWORTH
    MARK A. BUTTERWORTH Registered User
    NAWCC Life Member NAWCC Member
    Jul 4, 2009
    2,297
    89
    Diistributor of movements and movement parts.
    Muscatine, Iowa 52761
    Most of the Hermle units with this number were in fact used in the Zaandam clocks
  6. KLS
    KLS Registered User
    Apr 18, 2014
    64
    Netherlands
    It is from a small Zaanlander.
  7. KLS
    KLS Registered User
    Apr 18, 2014
    64
    Netherlands
    And the weights?
  8. KLS
    KLS Registered User
    Apr 18, 2014
    64
    Netherlands
  9. KLS
    KLS Registered User
    Apr 18, 2014
    64
    Netherlands
  10. KLS
    KLS Registered User
    Apr 18, 2014
    64
    Netherlands
  11. KLS
    KLS Registered User
    Apr 18, 2014
    64
    Netherlands
    Now clean it...Make it ready for inspection...
  12. dAz57
    dAz57 Registered User
    Dec 7, 2011
    2,018
    watchmaker
    sydney Australia
    Normally when you dismantle a movement like this, you remove the dial work first, then turn it face down and remove the pallet bridge and pallets, then remove the back plate, this way you don't disturb the mounting brackets, but yours were flopping all over the place so it's a moot point
  13. KLS
    KLS Registered User
    Apr 18, 2014
    64
    Netherlands
    Okee, Thanks dAz57
  14. KLS
    KLS Registered User
    Apr 18, 2014
    64
    Netherlands
    The result...
    Mvmt works like new, clock is painted with Annie Sloan, not ready yet...
  15. bangster
    bangster Moderator
    19,630
    388
    Wow. An EXCELLENT series of pictures.
  16. KLS
    KLS Registered User
    Apr 18, 2014
    64
    Netherlands
    #16 KLS, Mar 22, 2015
    Ready!! It looks old...
    Its a small Zaanlander 50 x 22 cm
    Found it in an old Barn in Maassluis in a lot with five other zaanlanders
    It was there for some years in terrible conditions, no heating and verry wet.
    First one is saved!! Its called number 43
    Here is the second... He was called number 32
    I must clean the movement and need a pendulum... 32 cm
    Its a big one, 65 cm
  17. disciple_dan
    disciple_dan Registered User
    Mar 10, 2016
    499
    33
    Clockmaker, General Flunky
    Plant City
    Nice work KLS.
    Can you tell me the weight requirement for that 261-080. I am thinking of buying one that has no weights with it. Thanks, Danny
  18. shutterbug
    42,701
    1,106
    This should answer your question (and the next) :)
    I recall the original weights were more polished though.
  19. disciple_dan
    Mar 10, 2016
    499
    33
    Plant City
    And the next question would be... Where can I find some?
    Thanks, SB. I found some over on the Antique Dutch Clockparts. They were original and made of solid brass I think. 80.00 shipped. Time savers are painted cast iron.
    I found this clock for 85.00 shipped so that would be 165.00 before I even worked on it.
    From what they are going for on ebay it's not that great an investment. Maybe I should let this one go.
  20. THTanner
    THTanner Registered User
    Jul 3, 2016
    2,562
    176
    Carson City, Nevada
    On these 261-080 in Zaandam, the mountings are on the front plate under the nuts that have to come off to separate the plates. I am working the same clock and movement from 2000 (M code) and it is a real pain to get the mountings back exactly to fit the old screw holes. I take closeup pics of the mounts before loosening the nuts, but that is just approximate. Put them back close without fully tightening the nuts, position in the case, wiggle them around till they all match then fully tighten. I hate these clocks.
  21. shutterbug
    42,701
    1,106
    That's not a terrible price, and remember that the weights will always have resale value :)
  22. disciple_dan
    Mar 10, 2016
    499
    33
    Plant City
    Yeah, good point. I'm still considering it. Thanks for all the good help.
    THTanner. I'm not a fan of those bolted on feet either. So hard to get them set right. In the past, I have made alignment marks on the feet and on the front plate and made sure the feet went back in the same position. It helped.
  23. THTanner
    Jul 3, 2016
    2,562
    176
    Carson City, Nevada
    On my own clock a few alignment scratches would work, but I hesitate to do that to a customer's clock. So on these I test mount them in the case without the chains a couple of times to get it right then tighten it all up and put the chains in for the final mounting
  24. disciple_dan
    Mar 10, 2016
    499
    33
    Plant City
    Yeah, I see what you mean. Maybe a pencil or fine felt tip would be better and then remove it with lacquer on a cotton swab. I'm sure many people have many ways of their own. Danny
    THTanner likes this.
