Female spring bars
Discussion in 'Wrist Watches' started by Walter W Kerrick, Feb 11, 2020.
  1. Walter W Kerrick
    Walter W Kerrick Registered User
    Feb 11, 2020
    14
    27
    Hi everybody. I recently recieved a Hamilton Piping Rock and while I'm very excited about this watch I can't seem to find any new spring bars for it. Does anyone here have a good source for these old female spring bars? Here I'd a gratuitous photo of the watch in question.
    viclip likes this.
  2. glenhead
    glenhead Registered User
    Nov 15, 2009
    1,085
    134
    Telecom Engineer
    Williamson County, Texas
  3. Walter W Kerrick
    Feb 11, 2020
    14
    27
    Thanks, I bought some from Esslinger and the diameter of the end cups are no where near large enough. To fit on the studs they need to be somewhere between 1.5 and 2mm. The Esslinger ones, and others I have looked at so far, have been under 1mm.
    I have not looked at Jules Borel or Startime yet, I will check out both of their offerings.
  4. EscapeWheel
    EscapeWheel Registered User
    Mar 19, 2003
    131
  5. Walter W Kerrick
    Feb 11, 2020
    14
    27
    Thanks, I have those saved on my watchlist but they are $30 for a pair. I actually found a pair on Jules Borel that say they have 1.7mm openings, if these ones don't work I'll give the ebay ones a try.
  6. glenhead
    Nov 15, 2009
    1,085
    134
    Telecom Engineer
    Hey, Walter, it didn't process that the studs on an old-old case like that are so big. I ran into that several years ago and obviously spaced it. Sorry about that. I got a pair from a friend after a long and fruitless search. Please let us know if you find a source for the danged things. Good luck!
    Glen
  7. Samie Smith
    Samie Smith Registered User
    Mar 22, 2012
    105
    26
    watchmaker
    Monticello ky.
    Walter I may have what you need I will have to look and see if I can find them if they will work I can send you a pair.
  8. 4thdimension
    4thdimension Registered User
    Oct 18, 2001
    2,420
    130
    I too have more than I will ever use and would be happy to provide some if needed.-Cort
  9. Samie Smith
    Mar 22, 2012
    105
    26
    watchmaker
    Monticello ky.
    Walter what length do you need I found the springs
  10. Walter W Kerrick
    Feb 11, 2020
    14
    27
    Thanks guys. Using Glen's advice I went to Jules Borel and found a pair I think will work. If this pair is also a wash I will let y'all know.
  11. Walter W Kerrick
    Feb 11, 2020
    14
    27
    Samie, I need 16mm. The ones I received from Jules Borel are also useless.
  12. Samie Smith
    Mar 22, 2012
    105
    26
    watchmaker
    Monticello ky.
    Walter I have that length the outside of the pin where it goes on the lug measures 1.92 mm the inside hole looks to be about 1.50.mm. where it fits over the lug I will take a look and see if I have any with a larger hole.. I found a few with a 1.90mm hole but they are too long..at 19mm
    These are thick on the hole end and could be drilled out to fit you lugs if you think these will work I can send you a set.
    Samie
  13. Walter W Kerrick
    Feb 11, 2020
    14
    27
    Samie, the ones on my watch need to be 1.27mm do those should work. I may have found some so let me run this lead down first. Thanks for the help.
  14. Steve Weikal
    Steve Weikal New Member
    Mar 13, 2020
    Hello everyone, really appreciate this discussion about the elusive vintage female spring bar, with end holes large enough to accommodate the pins of older watches. In cleaning up my grandfather’s Hamilton I’ve discovered that the spring bars are not the same – the one shown here works perfectly (and is a nifty piece of engineering); the other is a multi-piece mess that I fear might come loose, causing the watch to drop off my wrist without me knowing it.
    As Walter mentioned above, the end cups on the modern replacement spring bars from Esslinger, etc. are generally too small to accommodate the pins. If any of you can direct me to a source for an earlier vintage, 19mm spring bar that may have larger end cups, I would certainly appreciate it.
    Steve
  15. EscapeWheel
    Mar 19, 2003
    131
  16. Steve Weikal
    Mar 13, 2020
    Yes, I saw these at Cousins. I was hoping to get one or two locally vs. sourcing and shipping from overseas. But this may be the only option. I'd have to confirm that the 1.8 mm measurement is the inner diam. of the cup ends, which might work. Appreciate the suggestion. /sw
