CajunClock
My wife was given this wall clock by a family member. I can't find any info about it. It was not running, and when I opened it I found out why. The interior was black tar. It looked like someone years ago took it apart, (ruining the screw holes holding the clock face) and dumped oil in it.
I took out the mechanism and sprayed it down with carb cleaner. Globs of black came out of it. The mainspring popped out some so it was obviously stuck. I've oiled it with clock oil after cleaning it with q-tips best I can.
It now runs and chimes, although it does loose about 5 minutes per hour. The pendulum is screwed up to it's highest position. I'm sure it's going to take someone with more expertise than I have to get it right, but at least it works now. It appears the top bezel may have been changed? It has no glass yest.
Bottom line is, does anyone know anything about this clock? Also, any suggestions for a newbie?
