F.B.Butlin, Watchmaker, Huddersfield, Napoleon mantle clock. Any information please.
Discussion in 'Your Newest Clock Acquisition' started by JJ007, Mar 6, 2017.
  1. JJ007
    JJ007 Registered User
    Mar 6, 2017
    Hi all,
    I am researching the background of a Napoleon hat mantle clock.
    I has the following label on the back of the case door, "F.B.Butlin, Watchmaker, Huddersfield". I cannot see any other identifiers on the case and the movement (not removed from case).
    The clock has a time train and a chime train (hour chime and single chime on the half hour).
    Has anyone heard of F.B.Butlin, watchmakers of Huddersfield?
    Is there any easy way of identifying the name/type of movement?
    Thanks,
    Regards
    JJ007
  2. JTD
    JTD Registered User
    Sep 27, 2005
    3,943
    19
    Re: F.B.Butlin, Watchmaker, Huddersfield, Napoleon mantle clock. Any information plea
    Welcome to the board.
    I doubt whether F.B. Butlin (78, Lockwood Road, Huddersfield) had anything to do with the manufacture of this clock, he was likely the retailer. I suspect the movement is German and could have been made by almost any of the German clock manufacturers in the years between the wars. Is there anything written on the inner side of the gong stand?
    Someone may come along who can recognise the movement by sight.
    JTD
  3. JJ007
    Mar 6, 2017
    Thanks for the info, JTD.
    I am considering taking the movement out for cleaning and checking over so I will look for other clues.
    I will definitely take the gong stand out and see if there are any markings.
    If I find any I will post back on this thread.
  4. Tinker Dwight
    Tinker Dwight Registered User
    13,680
    I don't see any label like "Made in Germany" which leads me to think it might
    be a domestic made clock. You might look at Smith's clocks.
    This is called a striking clock, not a chiming clock. The round coil is
    a gong, not a chime.
  5. jmclaugh
    jmclaugh Registered User
    Jun 1, 2006
    3,612
    Devon
    The movement doesn't appear to match any UK made ones. at least in any reference material I have, maybe that stylized gong stand may be a better clue to identifying it.
  6. JJ007
    Mar 6, 2017
    Thanks for the additional information Tinker and jmclaugh.
  7. Andy Dervan
    Andy Dervan Registered User
    Oct 23, 2002
    2,244
    Hello JJOO7,
    The proper term for this case style is: Tambour.
    It was made in US, UK, and Germany and was popular in early 20th century probably 1910 - 1930.
    Andy Dervan
  8. JJ007
    Mar 6, 2017
    Thanks Andy for the additional info.
  9. Tinker Dwight
    13,680
    In any case, give the gong holder a good look on the other
    side.
    I couldn't find a match for that movement either. Still is is
    close in design.
  10. jmclaugh
    Jun 1, 2006
    3,612
    Devon
    Not in the UK where the case style is referred to as Napoleon Hat.
  11. novicetimekeeper
    Jul 26, 2015
    4,818
    Dorset
    We probably had rather more to do with Napoleon :)
    I had always wondered what a tambour case was.
  12. chimeclockfan
    chimeclockfan Registered User
    Dec 21, 2006
    3,347
    13
    Chime rod sets for antique clocks - please inquire
    WI
    Your clock's movement, dial, and gong were most likely made by Kienzle. Not all of their movements were signed. The case may be British made. Most British cases I've seen were veneered while German factory-original cases tended to be made of solid wood.
    There is no official name for this style - they are simply 'mantel clocks'' or 'table clocks' in all known factory literature.
  13. JJ007
    Mar 6, 2017
    Thank you everyone for your items of information.
    Much appreciated.
    I have removed the gong stand to view it's reverse side, unfortunately it is flat and unmarked.
    The case looks veneered in oak so based on what you have said, the case is highly likely to be British.
    The movement has now stopped and the pendulum will not swing for long, so now I am emboldened to remove the movement from the case. I have been watching YouTube videos so am comfortable at the minimum to remove it.
    Once removed I will then inspect the movement and will then decide if I want to either get some of the clock maker tools and enjoy taking it apart etc or if I will just take it to the clockmakers for repair. Financially it does not make sense to have a clockmaker do a service as I think this clock probably has a value of £30-50 but I am fascinated by the ingenuity and ability for a clock to function mechanically without electricity. I want to keep this baby alive! I don't feel it fits the 'disposable' category of throw away and cheaply replaced items.
  14. harold bain
    Donor NAWCC Member
    39,942
    Invest in some clock oil and learn what needs to be oiled and what doesn't, so you can do some good when you have the movement out. It may just need to be wound up, but oiling it won't do any harm.
  15. JJ007
    Mar 6, 2017
    The clock is wound.
    It ran for two days after I first received, fitted the pendulum and wound the clock.
    It only took a few winds till tight when received so I think it has sat partially wound with the pendulum removed for a long time.
    Because it only ran for two days before the pendulum stopped it did not take much winding till tight again. This time the pendulum stops within minutes.
    The pendulum's tick tock timing was audibly uneven from day one and I tried raising the clock on each side respectively with pennies, to no avail.
    On the two days that it did run, it lost perhaps 5 minutes a day but I can play around with the pendulum nut if I get the clock functioning again.
    The bearing holes that I can currently see while the movement is in the case look good and precise and not worn or egg shaped.
    I will acquire a suitable clock oil and apply the tiny amounts required if the whole movement looks to be without fault or excessive wear.
    Time will tell. Ha ha ha....
