Examples of Early American Lithographs
Discussion in 'Reverse Glass and Dial Painting' started by PatH, May 5, 2017.
  1. PatH
    PatH Registered User
    NAWCC Fellow NAWCC Member
    Dec 5, 2014
    1,655
    1,139
    Female
    Texas
    From Mike's 2/14/16 post...
    The last thing about this clock that was fun to run down was the history behind the tablet, which depicts "The Highland Chase." It shows a Scots Highland lad on his horse, with his dog at his side, racing through the mountains of Scotland. A little bit of Googling revealed that the image was published in volume 37 of Graham's Magazine (1850). Graham's Magazine was published by George Rex Graham in Philadelphia from 1841 to 1858. Edgar Allan Poe was the editor for a period during the 1840s. The magazine published short stories, poetry, book reviews, and music. It was also known for the high quality engravings found in it. "The Highland Chase" was engraved by Thomas B. Welch (1814-1874). Welch made engravings of many notable figures (James Madison, Benjamin Franklin, George Rogers Clark, and others) from the early years of the forming of the United States. [info courtesy of Wikipedia]
    Thanks for sharing this clock. I have been noticing recently that some of the sharp gothic, beehive and ripple cased clocks from this era, and from different CT makers, have what appear to be unpainted lithograph transfers. Some of them appear to be quickly and rather inexpertly positioned on the glass. I was wondering if you can tell from this one if the tablet appears to be unpainted because it is all backed with white paint, or is it truly unpainted? Do you have any ideas on when this style of tablet decoration was used? Was it prior to or later than the reverse painted transfers/decals? I have seen several images in clocks were one might be unpainted and the other painted, however, I haven't seen enough to be able to draw conclusions on whether the differences were by maker or by time period
    I'm hoping that you, RM, and some of the other more experienced collector/historians will be able to shed some light on this topic. Thanks!
    Pat
  2. rmarkowitz1_cee4a1
    Nov 26, 2009
    5,096
    841
    Re: Some Jerome clocks for viewing
    A number of methods were used to decorate the tablets of mass produced CT clocks.
    Beginning with hand painted glasses, over time the trend was towards cheaper faster easier methods of mass produced decoration culminating in the "silk screened" glasses used on the ubiquitous gingerbreads and clocks of that ilk.
    Stencils, decalcomania and lithographs were some of the means by which a basic pattern was placed on the glass. Sometimes a monochromatic color was applied behind it, sometimes, it would be enhanced with hand applied colors.
    And yes, sometimes the work was less than precise and the color doesn't quite stay between the lines. I have also seen absolutely original glasses where the image was off center or almost appears to have been cut down from a larger glass.
    I suspect that just as with the less expensive Currier and Ives litho's, when given hand coloring (yes some were not), there would be just a few colors and they were done on an almost assembly line bases. One person applying the green, the next the blue, the next the red. I was done quickly and expeditiously.
    Glasses where the decoration is cut and ground on a frosted background were also used. These tend to be clocks produced from about the late 1830's through the 1840's. These appear to have never been reverse decorated.
    RM
  3. PatH
    Dec 5, 2014
    1,655
    1,139
    Female
    Texas
    Thanks for the info, RM! I haven't seen one of the monochromatic tablets "in person" to tell if it was painted, or if the white color was due to the paper not being removed after the lithograph was applied. Glad to learn that some of the transfers were monochromatic. Are you aware of any monochromatic transfers in other colors besides white/ivory?
    Interesting thought that some of the tablets might have been cut down from a larger glass. This certainly would explain the off-center positioning and the need to quickly produce tablets.
    I've read quite a bit about the various methods of tablet decoration, but hadn't run across anything related to those without at least a minimal amount of color. However, it seemed logical that these could be turned out even more rapidly than the ones with 3 or 4 colors, leading me to assume they were later in the life-cycle of hand painted/decal/litho era.
    Bit of trivia related to this topic - word of the day: cockamamie. There is some thought that the word cockamamie was related to decalcomanie or decalcomania, although about 100 years later than the decals we associated with earlier decalcomania.
  4. George Nelson
    George Nelson Registered User
    NAWCC Member Deceased
    Oct 5, 2007
    931
    12
    Tennessee
    Pat H. and All,
    I have personally seen a light blue monochromatic transfer several times, and all in New Haven (not Jerome) steeple clocks. I wish I could remember the wording on the glass, but it pictured a horse drawn wagon proceeding towards the back of the picture in front of a walled church and cemetery. I used to own one, but long ago sold it. From what I remember, the back was indeed painted an off white, but the entire front image was as if it was printed on blue paper and then applied. I have also seen the same image in an all off-white version as well. Hope this helps a bit. If I come across the image anywhere, I'll PM you.
    Best,
    George
  5. rmarkowitz1_cee4a1
    Nov 26, 2009
    5,096
    841
    I've seen monochromatic tables in shades of weight, grey, greyish blue.
    Here's an example of one:
    I've also seen stenciled tablets that are monochromatic. Some are quite simple, others not. Here's an example:
    This particular one is by Fenn.
    RM
  6. George Nelson
    Oct 5, 2007
    931
    12
    Tennessee
    RM,
    Not to question you, but isn't the image of the column clock frosted? Or is it truly very thin paint?
    George
  7. rmarkowitz1_cee4a1
    Nov 26, 2009
    5,096
    841
    It's not frosted. It's paint or possibly a metallic powder that was "pounced" onto the glass after a sticky varnish was applied to hold it. The pattern was created using a stencil.
    If you tried to clean the back of the glass, it would wash off.
    RM
  8. George Nelson
    Oct 5, 2007
    931
    12
    Tennessee
    Thanks, RM! Learning more and more from you all of the time! I did know about "pouncing" from a stenciling class I once took. It was not a NAWCC sponsored class, and was quite poor...
    George
  9. PatH
    Dec 5, 2014
    1,655
    1,139
    Female
    Texas
    Thanks, George! It seems that both Greenwood and Baltimore Cemetery were used on clocks from this period. The Greenwood Cemetery includes a conveyance heading into the cemetery while Baltimore has a carriage traveling across the picture in front of a church that looks like a castle. Earlier this week I found a picture of a monochromatic Greenwood Cemetery tablet in an ogee. This seemed to have been a rather popular image in both ogee and steeple-cased clocks. Pretty amazing what buildings/scenes/events were reported in the newspapers/periodicals of the time - and each one was memorialized with very skilled engravings that had to be completed quickly before the building/scene/event was no longer noteworthy. I read recently that to expedite completion some of the images were actually divided into sections with each section completed by a different engraver. This might explain why a vertical line is visible in some of the images.
    Since this conversation is not specific to Jerome clocks, I'm wondering if we should ask a moderator to move this to a separate reverse glass painting thread.
  10. PatH
    Dec 5, 2014
    1,655
    1,139
    Female
    Texas
    RM, I've seen some tablets that were recreated using stencil, varnish and powder to achieve this frosted appearance, with excellent results. But I'd like to hear your thoughts on another possibility. In one of the old Bulletin articles on reverse glass painting, there was mention of gum arabic being used on clock tablets. It seems to me that varnish and bronzing powder would not wash off easily - at least not with just soap and/or water. However, looking at the current uses for gum arabic, and reading that it was used during this period as a binder for watercolor and in lithography, I've wondered if perhaps gum arabic rather than varnish was used as the base to create the etched look. This might explain why the frosting would wash off. Before I get some gum arabic and start experimenting (which might not be in the near future), I was wondering if you, or any other readers, are aware of anything that might substantiate or debunk this possibility?
    Thanks!
    Pat
  11. Jerome collector
    Jerome collector Registered User
    Sep 4, 2005
    830
    62
    Geologist, US Army Corps of Engineers
    Omaha, NE
    Pat,
    One of those weekends where I've found it next to impossible to sit down at the computer long enough to compose a response. RM, as always, has covered the details associated with the tablet variants. I'm posting three examples, including front and back, that illustrate some of the differences previously mentioned.
    The first, which I believe to be the earliest (say, late 1840s), shows the town of Albany, NY. It's from a mini-Empire-style Jerome clock with 30-hr fusee movement. There's clear evidence of application of multiple paint colors. The second, a view of Iranistan (P.T Barnum's villa), is from a Jerome steeple with 30-hr fusee movement that probably dates to no later than the early 1850s. It shows some application of paint, but far less than the Albany tablet. The third is the tablet you were asking about, from a Jerome steeple with 30-hr, spring-driven movement that likely dates to the early-mid 1850s. It does appear to have paint applied to the back: a brown-grey, an off-white, and a pale blue. At least I believe those were applied and are not part of the transfer.
  12. rmarkowitz1_cee4a1
    Nov 26, 2009
    5,096
    841
    Certainly gum Arabic is a possibility.
    It was used extensively.
    I have/do own lithographs, portrait miniatures, water colors and even silhouettes where it was applied to add "sheen" and visual highlight to an area.
    However, I have found it tends to become sticky in the presence of moisture or humidity. I have had the unfortunate experience of having some works on paper where this has occurred and adhered the work to the frame glass never to be separated, at least by me!
    SO, I'm not sure that gum Arabic would be the most stable and permanent "sticky" solution for a clock tablet?
    Not sure.
    Thanks for posting the examples.
    RM
  13. PatH
    Dec 5, 2014
    1,655
    1,139
    Female
    Texas
    Thanks, Mike and RM!
    Mike, I wish I could find a copy of the Iranistan print used in your tablet. So far, they seem rather elusive. Barnum is such an interesting character, and his home was definitely a showplace. Thanks for posting the three examples as they are excellent examples of different painting techniques. You're right that they seem to be applied paint rather than part of the transfer.
    RM, interesting to hear about gum arabic's reaction to moisture. This certainly wouldn't be optimal for a tablet. I'll keep reading and see if anything else shows up that would account for the ease with which the frosting is removed.
    Thanks again, to both of your for sharing your knowledge and experience!
    Pat
  14. George Nelson
    Oct 5, 2007
    931
    12
    Tennessee
    Hi, Pat,
    Greenwood Cemetery is the one I had in mind! Thanks for jogging my memory, and also for explaining the lines I've noticed in some of the transfers. You are amazingly knowledgeable about all of this.
    Moving this thread to the Reverse Glass Painting thread is fine with me.
    Warmest regards to all,
    George
  15. PatH
    Dec 5, 2014
    1,655
    1,139
    Female
    Texas
    Hi, George.
    Thanks for your kind words. We all keep learning from each other!
    By the way, I have requested that these posts be moved to the Reverse Glass Painting forum.
    Have a great week!
    Pat
  16. leeinv66
    leeinv66 Moderator
    Mar 31, 2005
    9,934
    213
    Industry Specialist
    Launceston Tasmania
  17. PatH
    Dec 5, 2014
    1,655
    1,139
    Female
    Texas
    Thanks, Peter!
  18. Tom Vaughn
    Tom Vaughn Registered User
    Feb 10, 2018
    69
    31
    Here is a very early tablet featuring Henry C. Smith's residence. This one is a decalcomania, meaning that the print was carved in a cross cut section of a log, printed on a tissue like paper, glued or varnished to the tablet and the paper washed away with water leaving the print on the glass. Color was then added for a finished tablet. This tablet is very early, probably 1850 or even earlier. It is cased in a H Webster from Burlington Ogee clock. This is the only one (decal) I've seen of this house, however, I've seen the house painted free hand on some Eli Terry Jr. shelf clocks as early as 1830. The house was built by Henry C. Smith in 1825, and he built his clock factory in the rear of the home. This tablet is the only known depiction of Henry C. Smith's actual clock shop (visible in the center left). Henry C. Smith sold the entire property to Augustus C. Shelton in 1850, who opened up a monstrous carriage factory near and around the home. This tablet has many applied colors and layers of paint, even some of the trees are painted free hand to add some decoration. Because of the date on the H Webster clock, and the fact that the house did not belong to Henry C. Smith after 1850 suggests that this is an earlier tablet. Even tho they could have certainly been printing with the same block print for up to a decade or two after it was made, It would have had to have been carved while the house was still Henry C. Smith's. The house still stands today, (It recently sold if anyone is interested in seeing the interior online), My friend Pat ran it as a bed and breakfast for a few years. This may be a product of William B. Fenn, who was working less than a mile from this house, but the Clock Museum does not have the original block print for this tablet with Fenn's collection, so we cannot prove it.
    PatH and Jim DuBois like this.
  19. Paul H
    Paul H Registered User
    Jun 23, 2005
    275
    Tom;
    Thanks for posting this image. That is a fabulous Tablet! Is this a clock you own?
    My first thought is that this looks more like a Lithograph as opposed to a wood cut engraving.
    Is a higher resolution image available or possible a picture of the back side of the tablet?
  20. Tom Vaughn
    Feb 10, 2018
    69
    31
    This clock is on loan to the Plymouth Historical Society... I don't have a better photo at the moment, but next time I stop in I'll try and take one of the front and back. It looks similar to the wood blocks I've seen, but it may be a lithograph...
  21. Paul H
    Jun 23, 2005
    275
    I actually grew up in Waterbury Ct.... . A man from our church named Don Brown collected clocks and lived in Plymouth Ct at the time (1980’s). He told me that he had a clock with this tablet and sold it to the man who actually lived in the same house owned by Henry C Smith! I never got to see the clock.... I wonder if this could be the same one:???:
    I wrote an article on Lithographs... See Bulletin #397
    And I am currently writing an extensive piece on wood cut engravings as used in clock tablets. The ACWM in Bristol has been very helpful on this project...
    Thanks again for posting the image. While I've known of its existence for a long time, this is the first I've seen it.
