Escapement problems with Seth Thomas
Discussion in 'Clock Repair' started by Jeff Salmon, Jan 12, 2018.
  1. Jeff Salmon
    Jeff Salmon Registered User
    670
    I am working on a Seth Thomas #10 calendar clock with the Lyre movement. It has not run for many years. The present owner has not seen the clock run for 25 years or so. The clock has previously been bushed, the pivots were fine, but I polished them, and the movement was cleaned etc. It appears that the escapement is a source of the problem. I suspect that the pallet strip and the pin have been changed and I can't get any type of adjustment will make the clock run for more than a minute or so. The movement has a 50 tooth escape wheel, 1.325" in diameter, and the span of 9 1/2 teeth is .655". The verge wire has obviously been changed as it is soldered on to the pallet strip. The distance between the pallet faces is also .655". Perhaps the little plate that the pin is on is also changed. The plate/pin assembly is fixed to the movement by a brass screw.
    Maybe this pallet strip was made, but incorrectly. The pin that the verge saddle fits on has been changed, or the whole piece is a replacement. One can see that the hole is enlarged and oval and this allows adjustment up and down as well as in an arc using the screw as a pivot point. This combination of adjustments makes it troublesome to find a proper position.
    When I find what seems to be a good position for the verge, with the drop and lock seeming to work properly, and the beat set, the clock suddenly stops within a few seconds. The illustration in Tranh's book are very grainy and it is difficult to magnify.
    If anyone has some suggestions, I would appreciate them.
  2. bruce linde
    bruce linde Technical Admin
    7,130
    906
    oakland, ca.
    anyway you could upload a video of it running and then stopping?
  3. Jeff Salmon
    670
    I'll work on that this weekend.
  4. Willie X
    Willie X Registered User
    12,774
    985
    #4 Willie X, Jan 12, 2018
    I see some misplaced bushings, which are to long, and some deformed teeth on the escapewheel. I don't think you have a #10 calandar movement there?
    That little plate that holds the pallet pivot wire is not made properly. The screw should be steel and have a head like a gun screw and there should be no slot, just a snug fitting round hole.
  5. THTanner
    THTanner Registered User
    NAWCC Member Donor
    Jul 3, 2016
    2,715
    214
    Carson City, Nevada
    here is a you tube of basically same movement set up and running smoothly
    note the number of teeth between the pallets, the angle of the mounting - - hope this helps some
    Jeff Salmon likes this.
  6. Jeff Salmon
    670
    The movement appears to be the same as in Tran's Calendar Clock book, page 263. I do agree that the plate for the pallet pivot may be not correct (especially the oval hole). I will re-examine the escape wheel teeth. I realize that the escape wheel bushing is long, it was done a long time ago by someone else.
  7. Steven Thornberry
    Jan 15, 2004
    22,351
    1,123
    Ne’er do well
    Here and there
    What Tran seems to show is a semi-deadbeat escapement. Yours is obviously recoil, but I wonder whether someone in the past had fiddled around, reversing the escape wheel and adding a replacement verge, with unhappy results.
  8. shutterbug
    43,786
    1,282
    The verge looks ok to me. It would be good to see the clock running in a video though. I suspect you have a different issue. I do note some of your EW teeth are bent at the tips. That probably wouldn't stop the clock, but would make in go in and out of beat.
  9. THTanner
    NAWCC Member Donor
    Jul 3, 2016
    2,715
    214
    Carson City, Nevada
    And there is one short / broken EW tooth about 6 teeth clockwise of 12 oclock position in the picture
  10. Willie X
    12,774
    985
    Another short one about 4 to the left of th bottom. Several bent ones too.
  11. Jeff Salmon
    670
    Good call on the escapement. The escape wheel is reversed as shown in Tran's book and the pallets are now recoil. I don't know why someone would do this, but now I have to fix it.
    THTanner likes this.
  12. Willie X
    12,774
    985
    It probably was made as a recoil. I don't have the figures but it would be interesting to know how many Lyre plate movements were made with recoil vs deadbeat escapements. I always though that the recoil was early and the deadbeat was later but that may or may not be true. Same questions could be asked about the shouldered S-T movements of the same era. Willie X
  13. Jeff Salmon
    670
    #13 Jeff Salmon, Jan 13, 2018
    I have spent the day watching football and working on the escapement. I reversed the escape wheel and, in fact, some previous repairer scratched something on the back of the hub for the escape wheel. Wonder why. I had a half-deadbeat verge to try and I fit a new pin. I also checked the trueness of the escape wheel and found it was slightly out of true, so that was fixed. I made a new bushing for the escape wheel bridge. Now to another question: I notice in the pictures of original clocks in Tran's book that the verge wire is longer than what was on the clock when I received it. How critical is the length of this? I am interested in the length of it before I make the small loop that the suspension spring fit in. This will be a test to see if the clock runs at all.
