Escape wheel woes.
Discussion in 'Clock Repair' started by dumpsterdiver, Dec 1, 2018.
  1. dumpsterdiver
    dumpsterdiver Registered User
    Apr 12, 2008
    139
    So, this is off a Wag on wall from a client's clock. My first clue of "interesting" repairs was that the two removable panels were epoxied into the frame. Once I got those out I found this. It looks like someone took a Dremel grinder to it. Since it is this section I was thinking of setting up my mill and cutting back the teeth and re-tipping them. Anyone ever tip this many teeth or is cutting a new wheel faster? teeth.JPG image.png
  2. bangster
    bangster Moderator
    19,100
    295
    What in the Hey was somebody thinking? :emoji_anguished::emoji_confounded:
    dumpsterdiver likes this.
  3. R&A
    R&A Registered User
    Oct 21, 2008
    4,130
    86
    Why don't you just make a new one if you going to go to all that trouble. You will have to make more changes if you do this to the Verge also.
  4. Dick Feldman
    Dick Feldman Registered User
    Sep 1, 2000
    2,083
    69
    Colorado, usa
    How does your luck run?
    Depending on the diameter of the wheel and the number of teeth, you might find a suitable replacement at Timesavers or one of the other suppliers.
    It is not impossible to cut a new escape wheel.
    What method do you plan to use if that is your option?
    Do you have the proper tooling to make a cutter?
    Or do you have a suitable cutter?
    Does the clock owner know that straightening out that mess may cost more than six of those clocks are worth?
    That may be the deciding factor.
    Dick
  5. Dick Feldman
    Sep 1, 2000
    2,083
    69
    Colorado, usa
    Oh, Was the previous clock repairer and the owner the same person?
    D
  6. R. Croswell
    R. Croswell Registered User
    9,223
    495
    In my opinion, that wheel is history. I wouldn't waste any time on it. What Dick said, see if a new one from Timesavers will fit. I believe they also sell escape wheels with matching verge, which probably would need final finishing and adjustment.
  7. shimmystep
    shimmystep Registered User
    Mar 5, 2012
    4,084
    72
    Cambridge, UK
    I agree with Robert. Personally I'd make a new one, or find a replacement.
  8. Joseph Bautsch
    Dec 9, 2006
    1,113
    123
    Atlanta, GA
    Agreed, it’s toast. Maybe Timesavers will have the escape wheel and verge set you need.
  9. dumpsterdiver
    Apr 12, 2008
    139
    I will probably end up doing that. I was just seeing if I could salvage the old one. Thanks!
  10. dumpsterdiver
    Apr 12, 2008
    139
    Haha, Someone else had worked on it and not the owner. It is a wag in a tall case and has been in their family for a couple of generations. So she is attached to it.
  11. dumpsterdiver
    Apr 12, 2008
    139
    Oh, and I have a mill and CNC rotary table. I have made wheels for bell strikes but I have not made an escape wheel since I was in school 11 years ago. I'll have to find my notes from that class.
  12. kinsler33
    kinsler33 Registered User
    Aug 17, 2014
    2,790
    224
    Science teacher, writer
    Lancaster, Ohio, USA
    I don't know why, but I didn't have any luck with the one verge/escape wheel set I bought from Timesavers for a fifty-tooth escapement. I'd expected it to be fairly foolproof, but it wasn't.
    Since I have neither Mr D.Diver's equipment nor his skill my own inclination would be to try to clean up that escape wheel as best I could with a suitable file.
  13. dumpsterdiver
    Apr 12, 2008
    139
    I am going to fuss with it some just for my own interest.
  14. Keith Conklin
    Keith Conklin Registered User
    Aug 22, 2018
    33
    Selden, New York
    I might be mistaken but looking closely at those photos, I wanna bet that someone made that wheel by hand.
    If that is the case I am kinda impressed at the effort.
  15. R. Croswell
    9,223
    495
    That's not surprising, nothing about an escapement is going to be "foolproof" except perhaps an exact replacement part from the original maker and even that may require adjustment. I've found the escape wheels from Timesavers to be OK but the verges usually require considerable work.
  16. Willie X
    Willie X Registered User
    11,741
    609
    If you have the proper files and a lot of time and patience, it should be doable. I always start by undoing all the bends in the bent teeth with round nose pliers or big tweezers. Willie X
