Escape Wheel Diameter
Discussion in 'Clock Construction' started by dandydude, Sep 10, 2018.
  1. dandydude
    dandydude Registered User
    Nov 30, 2014
    221
    Clockmaker
    India
    What do you think is the optimum size/diameter for a 30 teeth EW. The escapement is a Graham Dead Beat). The clock has a seconds pendulum. I would like to make it as small as possible to make it efficient. Efficient as in i am trying to use the lowest driving weight possible. One issue with reducing the diameter is the teeth thickness gets smaller and looks really weak.
    Dandydude
  2. Allan Wolff
    Allan Wolff Moderator
    Mar 17, 2005
    614
    37
    Tulsa, OK
    I don't know if it is the optimum size, but most of them I see are approximately 1 inch (25mm) in diameter.
  3. Jim DuBois
    Jim DuBois Registered User
    NAWCC Member Sponsor
    Jun 14, 2008
    2,554
    420
    Magnolia, TX
    I find it more difficult to get the geometry correct on smaller escapements. One of the better high precision escape wheels I have recently seen was a very thin, very thinly spoked wheel made of titanium. It was about 2" in diameter.
  4. dandydude
    Nov 30, 2014
    221
    Clockmaker
    India
    Hi Jim,
    I currently use a 45mm dia escape wheel. I like it because the tooth thickness is comfortable. I would however like to make it smaller to make it efficient. Lighter also is on the agenda. I thought of titanium too. However because of the abrasion issue with titanium I thought of ti-n coating the teeth. Best of both worlds. I would still like to reduce the diameter.
  5. dandydude
    Nov 30, 2014
    221
    Clockmaker
    India
    Hi alan.
    I thought most of Of the escape wheels that are as small as 25mm are with a bent strip pallet. Are they really used with good regulator clocks?
