English Dial Clock. Dial Repair and Repaint
Micam100
Nov 11, 2019
184
46
71
I previously posted this clock late last year: https://mb.nawcc.org/threads/english-fusee-age-and-bent-brass.163999/
The dial had a bad sharpie touch up and the signature had been removed along with the layer of paint underneath (and any chance of discovering the maker). Two dial feet had been broken and poorly repaired, and the other two were weakened.
This clock probably dates from around mid-nineteenth century, but I don't believe it is historically significant. I decided to repair and repaint the dial.
Some before, during and after photos attached.
I used the smallest Micron pen (water based) for the minute circles and the smallest sharpie I could find for the number outlines. For the number fill, I used a water-based 3mm calligraphy pen which gave a lovely (to my eye) satiny finish rather than a hard black. I'm pretty sure the water-based inks will need a sealer, but I'll leave it cure for a few months and test.
There are a few small errors and blemishes, but I probably won't try to correct them. I was very nervous about attempting this but I'm happy with the result.
Michael
novicetimekeeper
Jul 26, 2015
11,485
1,024
Dorset
Looks good, I send my dials away for repaint if required so have no experience of self refinishing. If there ever was a signature it was unlikely to be the maker as from the beginning of dial clocks they were virtually all bought in from somewhere else.
Micam100
Nov 11, 2019
184
46
71
Thanks Nick. Yes, I guess more likely a retailer's signature but disappointing to see the removal of any link (however tenuous) back to the origins of the movement, case and dial makers.
Michael
Vernon
Dec 9, 2006
1,140
158
It looks fantastic! What is the base white and how was it applied? Thanks
Vernon
Micam100
Nov 11, 2019
184
46
71
Vernon
Thanks Vernon. I made a couple of dummy dials and tried a couple of colours and went with this one: Rattle can as pictured – colour "Surfmist". You won't have this brand in your part of the world. Iron dial, taken back to bare metal, five coats of red oxide primer, sanded between coats to give a smooth finish and to cover some gouges in the metal and some evidence of my riveting the dial feet. Several finish coats. Where do those insects come from when you start painting?
Michael
169,773
1,481,794
49,157
DavidEckman
2,965
