Enamel pocket watch dials.
Rengersj
May 9, 2021
Hello, I want to clean up some different enamel dials on my pocket watches. What type of cleaner should be used?
Thanks,
Joe
gmorse
12,748
2,301
Hi Joe,
I find that denture cleaner is very effective, as long as you're sure that all the lettering on the dial is fired in, ie, under the glaze.
Reactions: musicguy
Rick Hufnagel
Just Rick!
Oct 25, 2018
2,577
3,916
37
Pittsburgh pa
Here are two examples I actually did this evening. Both cleaned in denture cleaner.
I don't have before pictures, but can assure you they were crusty buggers. The #45 dial in the first picture has a few light hairlines and the #49 dial in the second picture has quite a few good hairlines in the upper half. Both came out very well after soaking for about ten minutes, brushing with a soft plastic brush, and then another soak for about 5 minutes... Then rinse and dry.
These are regular enamel dials. If your dials are glass enamel, the hairlines will not come out as well, but it will still greatly improve the look.
gmorse
12,748
2,301
Hi Rick,
I'm not sure why you make the distinction, because vitreous enamels are effectively glass.
Rick Hufnagel
Just Rick!
Oct 25, 2018
2,577
3,916
37
Pittsburgh pa
Hello Graham,
Possibly, your more accustomed to them being labeled hard or soft enamel. I realize in theory its a essentially glass, but American companies called soft enamel dials "glass enamel". Likely because it has more of a very shiney, glass like surface appearance.
Elgin Material Catalog dated may 1915.
gmorse
12,748
2,301
Hi Rick,
I'm not so sure about 'hard' or 'soft, but the higher temperature enamels on the best quality English dials were usually known as 'Venetian', and the higher fusing temperatures necessary meant that they were enamelled on gold rather than copper. Divergence of language!
Reactions: Rick Hufnagel
Rick Hufnagel
Just Rick!
Oct 25, 2018
2,577
3,916
37
Pittsburgh pa
I don't understand the hard or soft distinction either... To me it seems the definitions should be reversed.
Venetian is certainly a better term, thanks!
168,105
1,465,943
48,080
The Silver Kitty
2,954
Last book
400 day pendulums by happycusa
