Good day folks! I have an Emperor Westminster chime, lunar phase clock with a Hermle 341-020 pendulum driven movement. It has run extremely fast since I first acquired it. The only way I have successfully regulated it is by taping coins to the pendulum. To indicate how fast it is: It was race up to 2-3 hours ahead
I measured the pendulum length and it is 11 cm which is what I understand the stamped numbers indicate.
When I got it I found a “spare” suspension spring in the case. I’ve noticed that the pendulum travel (side-to-side) is practically nonexistent. The seller’s wife told me the seller liked to “tinker” with his clocks. It finally hit me that the problem may be too short a suspension spring, especially in light of the fact that I found a “spare” in the case.
What are your thoughts on my theory?
Any way I can find out what the correct length suspension spring it is supposed to have?
