Eli Terry
Discussion in 'Wood Movement Clocks' started by Carl Spencer, Jul 7, 2017.
  1. Carl Spencer
    Carl Spencer Registered User
    Apr 7, 2015
    62
    Would like to find information on cutting wood clock gears. Have the ability to cut the teeth but there has to be some magic numbers as how high or low from the center the first cut has to be. Can't find the correct information in the machinery's handbook. Any old editions on this subject would be very helpful. Thanks, Carl in NC.
  2. Troy Livingston
    Troy Livingston Registered User
    Aug 28, 2006
    117
    Aerospace Stress Engineer
    Melrose, FL
    #2 Troy Livingston, Jul 8, 2017
    Carl,
    None of the standard references on gearing will be of help here. I think this was covered in an old issue of the Cogcounter's Journal but can't remember if it has been digitized yet. You should consider joining the chapter, the Journals are a treasure trove of wood works information and the people are good bunch.
    Also, I believe George Bruno covered this in his plans for the standard Terry shelf movement, available at the American Clock and Watch Museum.
    http://www.clockandwatchmuseum.org/apps/webstore/products/show/3510292
    Troy
Similar Threads - Terry Forum Date
Terry Running Fast Wood Movement Clocks Thursday at 11:29 PM
Eli Terry Jr Eight Day Just Acquired Wood Movement Clocks Apr 22, 2017
Terry Type 1.111 Movement Questions Wood Movement Clocks Mar 21, 2017
Terry-Type Lockset Key Question Wood Movement Clocks Mar 2, 2017
Finished Eli Terry Pillar and Scroll Movement Wood Movement Clocks Feb 4, 2017
