Elgin Running Diagnostics
Discussion in 'Watch Repair' started by spiro13, Apr 26, 2015.
  1. spiro13
    spiro13 Registered User
    Jun 10, 2010
    109
    Hi
    I have a Elgin grade 460 movement. It has been cleaned and oiled and a new #6095 alloy mainspring installed. The Timegrapher numbers are: Amp - 240deg., Beat Error - 1.3 and running appx. 3min. slow with the regulator on full fast. I would appreciate suggestions as to what to look for to get the movement to run better.
    Thank you,
    Tony
  2. psfred
    psfred Registered User
    Sep 25, 2009
    975
    Check the poise on the balance, and verify that at room temperature the balance rim is even at the split -- even if poised, too far out will make the watch very slow.
    And look for timing washers under the screws on the balance -- not impossible someone "fixed" a set mainspring by slowing the balance down....
    Peter
  3. Skutt50
    Skutt50 Registered User
    Mar 14, 2008
    3,479
    107
    Gothenburg
    You also should check the adjustment pin(s). If they are gaped to much the watch will run slow.
  4. spiro13
    Jun 10, 2010
    109
    Thanks much for the suggestions.
    Tony
