American PW Elgin jumping from Wind Position to Set position on its own
wilsonpaule
Oct 23, 2011
348
Hudson, Quebec
I am revisiting a watch I worked on a long time ago. It is a pretty basic size 6 elgin, but I like it because it is in a Hunter case and it has a fancy dial, Serial # 5040594.
I have it running very well, good amplitude, keeps great time, but it has one major problem. It will not remain in wind mode. It is a stem wind, stem set watch, and it will jump out of wind mode on its own. Two problems with this: 1) To wind it, I have to put downwards pressure on the crown to keep it engaged. 2) More seriously, when it slips out of wind mode while running, the hands no longer keep time.
I have attached a picture of the mechanism below. All the springs appear to be in the correct place. The watch switches from wind to set and back very smoothly, but it will just not stay in wind mode. Could this be something to do with the sleeve? I have adjusted the sleeve depth so that the stem is at the correct depth to wind the watch, but could the sleeve not doing it's job by keeping the stem down in set mode? (This is the only answer i can come up with after working on this problem for far too long!).
viclip
Jul 20, 2018
838
606
93
Just a wild stab at it.
I recently acquired a 12s Elgin which was behaving strangely in terms of winding/setting. Upon close examination I found a small lever adjacent to the pillar plate. Lo & behold the watch had one of those mechanisms allowing it to be forced to stay in winding mode when removed from the case. And the little lever was only partly engaged thus the setting mechanism continued to interfere.
After figuring out which way the lever needed to be to allow the watch to return to its normal uncased state of being in setting mode, the watch functioned wonderfully!
NC Plumber
Jan 15, 2011
413
22
I've encountered stems that were worn down enough that the sleeve was unable to hold it in position.
wilsonpaule
Oct 23, 2011
348
Hudson, Quebec
Yes, it was the sleeve. It was worn to the point where it wouldn't hold the stem in set mode. Replaced it and the watch is now running happily!
168,869
1,473,545
48,629
Mirela
2,955
