American PW elgin grade 50 mainspring
Discussion in 'Watch Repair' started by syeht, Apr 8, 2010.
  1. syeht
    syeht Registered User
    Jun 26, 2009
    24
    Looking for a mainspring for an Elgin grade 50. 16s, movement 1374633 and possibly someone to get it running and a case. 1a.jpg
  2. Don Dahlberg
    Don Dahlberg Registered User
    Aug 31, 2000
    3,425
    14
    The mainspring would be a Elgin 817 or Bestfit JA104 (or a JA105 would do). Of course, if you are not doing the work, then finding a mainspring is the problem of the watchmaker.
    Any 16 size case appropriate for 1882 would do. They were not factory cased. You went into the jeweler and chose a movement and a case and the jeweler joined them.
    We cannot recommend a watchmaker if we do not know where you are.
    Don
  3. Tom Huber
    Tom Huber Registered User
    Dec 9, 2000
    3,034
    177
    Track & cross Country Coach
    Indiana PA
    I would like to respectfully disagree with Don D. on the casing of this watch. My experience is that the movement is slightly thicker that a standard 16 size and will not fit a standard 16S case. The movement also has a male winding stem and requires a female stem in the case.
    Tom
  4. mrbill
    mrbill Registered User
    Jun 5, 2006
    652
    Couple of id pics may help Id of movement and a listing of MSpg's
  5. s. smith
    s. smith Registered User
    Oct 13, 2006
    582
    I belive the end of the mainspring in these is shaped more like the 2542 spring in the picture the last one of these i serviced i used the 817 spring ,,what i did was cut one of the tabs off the 817 and filed a notch in the side too hook in the barrel,,you will not find a 2542 in white so the only thing too do is make the 817 work,,i will be taking one of these apart in the morning not exactley the same grade but a covertiable with a 3 finger bridge ,,the barrel i belive is the same i will take a picture and post it.
    -> posts merged by system <-
    picture of springs
  6. s. smith
    Oct 13, 2006
    582
    I need too correct my mistake don is right on the mainspring it does use the 817 another one i have on the bench takes the hook style mainspring .
  7. dalesr
    dalesr Registered User
    Jan 4, 2009
    225
    New Jersey
    How do I order the right mainspring for my Elgin pocket watches below? I will be taking a class in June and may need to replace the mainsprings. Any help would be greatly appreciated.
    1943 Elgin Pocket watch, 17 jewels, size 16
    1947 Elgin Pocket watch, 17 jewels, size 16
  8. dalesr
    Jan 4, 2009
    225
    New Jersey
    I opened the back of the pocket watches and obtained serial numbers. I reference an Elgin database to idenitfy these watches and now more confused as to which spring to order.
    Elgin serial number 42280753 1943 Grade 387 Size 16s 17 Jewels
    Elgin serial number J392405 1947 Grade 574 Size 16s Jewels
    Elgin serial number 33798095 1932 Grade 313 Size 16s 15 Jewels
    The pocket watch J392405 has a grade 574 and the listing for mainsprings is be models/grades. The mainspring 6164 in Merritts catalog supports dp grades 573,574,etc...but still not sure if this is the right one.
    Do I need to remove old spring and measure Width, Strength, and Length to find proper replacement or is there a mainspring replacement based on the serial numbers listed?
  9. sderek
    sderek Registered User
    Jan 8, 2009
    2,689
    Watch repair/ Watch sales
    USA
    #9 sderek, May 2, 2010
    You can order most available Elgin parts from Jules borel (www.julesborel.com) based on the grade. The grade 574 takes this mainspring... MS-JA107
    MAINSPRING 20-4-24 DBH
    GR 7089-DBH
    According to my Swigart's catalog, the original part number is 6164. According to Jules borel's Horological Products Catalog (p.98), MS-JA107 is the mainspring to be used for Elgin's pn 6164.
    You can look up most Elgin original part numbers using one of these sources: Elgin's 1915 Material Catalog, or 1950 Material Catalog, or 43449.jpg .
    With most of these sources- you use the class to look up the part number.
  10. dalesr
    Jan 4, 2009
    225
    New Jersey
    Sderek,
    Thanks for this information. I will check Jules web site and it is nice to know that I use the class to find its replacement mainspring.
    -Ray
