I picked up another Elgin grade 342 to go with the other ones that I have and so far out of the 5 runs of 1000 I have one from the first, second(this one) and two from the 5th run. I have noticed that Elgin did a rolling change with each run of movements, first says adjusted, 2nd says adjusted 3 positions, and 5th say adjusted 4 positions and I will continue with finding one for runs 3 and 4 to see what they have engraved on them. Usually they are not that expensive, typically less than $80 and decent LS 17J movements but this one has a "Platold" case. I did some searches and I guess it this "Platold" case has been mentioned in the past on here but the link appears to be "busted" (maybe so old it doesn't work anymore). From the pictures it appears to have silveroid/stainless steel bezel and back with a gold filled center ring. Is this correct?
