Elgin convertible 3 finger bridge
model1857guy
Sep 24, 2016
543
242
34
Norton, Massachusetts
I have this Elgin convertible that I'm eventually going to get around to fixing, doesn't need much, just need hands, a correct bow and a good cleaning and oiling.
My question is, I see a fair amount of convertibles out there. But almost all I see are regular 3/4 plate, I don't seem to see many of these 3 finger bridge convertibles. How uncommon are they?
musicguy
Jan 12, 2017
7,579
4,090
New York State
Elgin,org says 16000 made so not uncommon but the Grade 86 is in high demand among collectors
It's good that yours came in a case because they don't fit a standard case.
[ELGIN] Online Elgin Database
Rob
Brad Maisto
Oct 1, 2000
741
214
66
Grandview, IN
The Elgin convertibles are interesting movements and was a concept ahead of its time. There was an Indiana Chapter 18 member that got me hooked on them. Typically they are not in true convertible cases and when you try to find a replacement minute hand, good luck as the hole required to fit to the arbor is unusually small as compared to other 16S watches. Elgin also made the convertible in a gilt plate grade. Most convertibles that were made have solid gold screws in the balance wheel, which in my humble opinion made them a higher grade watch. You do have a nice example of an Elgin convertible.
Brad Maisto, Kentucky Floral #44 Secretary
model1857guy
Sep 24, 2016
543
242
34
Thanks! I have one of the gilt ones, grade 49 in its original coin case.
Nathan Moore
NAWCC Business
Dec 29, 2011
428
607
93
The 3-Finger Elgin Interchangeable model was produced in four grades:
91
21-Jewel, Nickel, Adjusted to Positions, Temperature, and Isochronism
1 Run: 942,001-943,000
Production: ~500
(Evidence supports that only first 500 of run manufactured)
90
13-Jewels, Gilt, Unadjusted
1 Run: 941,001-942,000
Production: ~1,000
(Evidence supports that the entire run may not have been manufactured)
86
15-Jewels, Nickel, Adjusted
16 Runs Spanning 701,001 to 6,337,000
Production; ~15,700
(Evidence supports that only first 700 of last run manufactured)
85
15-Jewels, Gilt, Adjusted
3 Runs Spanning 700,001-1,214,000
Production: ~3,000
(Evidence supports that the entire last run may not have been manufactured)
Grade 91 is the most collectible grade in the 16-Size Model 2 production and was one of Elgin's premier movements at the time. In comparison, the Grade 86 production was more extensive.
Tom McIntyre
Technical Admin
NAWCC Star Fellow
NAWCC Ruby Member
Aug 24, 2000
83,960
1,906
84
Boston
awco.org
This may be true, but apart from the carved plate to give the 3 finger appearance, the 72 and 91 are essentially the same. Some collectors may actually prefer the 3/4 plate to the 3 finger bridge.
Nathan Moore
NAWCC Business
Dec 29, 2011
428
607
93
Agreed. The Grade 72 would certainly be considered the most collectible16-Size Model 1 and compliments the Grade 91 excellently. Beautiful movement.
musicguy
Jan 12, 2017
7,579
4,090
New York State
If anyone ever wanted to donate a Grade 72 or a 91 to me that would be nice,
but I'm quite happy with my grade 50 3/4 plate that I got from the wife of the Grandson of the
original owner(who sadly had dementia and wife was selling all his stuff).
Rob
Reactions: Paul Sullivan
thesnark17
Jul 11, 2020
66
47
90
Production: ~1,000
I was reviewing this thread today, and realized I had just seen a grade 90 movement on ebay.
13 jewels, gilt, not marked adjusted, simple regulator: SN 941,782.
Based on that, at least 800 should have been manufactured.
Fred Hansen
Aug 18, 2002
5,442
560
91
Production: ~500
I’ve yet to see evidence of more than the first 350 from the Grade 91 run being made. Can you show any example from the 942351 to 942500 serial range?
I’ve probably seen 50 or more examples from 942001 to 942350 range, but seen zero from anything over 942350.
Nathan Moore
NAWCC Business
Dec 29, 2011
428
607
93
That post is from years ago and should be updated accordingly. My current estimates for Grade 91 align with the 350 figure, with the necessary note of unusual anomalies found at #942854 and #942969 (statistical support, not seen or verified).
For the sake of updating the thread, here are the current production estimates for the interchangeable bridge model:
91
Production: ~350
(Evidence supports that only first 350 of run manufactured, statistical anomalies at 942854 and 942969)
90
Production: ~800
(Evidence supports that only first 800 of the run manufactured)
86
Production; ~15,700
85
Production: ~2,100
(Evidence supports that only first 100 of last run may have been manufactured, statistical anomalies at 1213595 and 1213703)
This yields approximately 18,950 bridge model interchangeable movements produced, with the Grade 86 accounting for 82.8% of production.
Fred Hansen
Aug 18, 2002
5,442
560
Thanks and will be interesting to see if those anomalies ever surface as actual examples or if they may be reporting errors.
Nathan Moore
NAWCC Business
Dec 29, 2011
428
607
93
Agreed. I should clarify that those are not reported serial numbers. The anomalies are derived from a statistical analysis that indicates probable and possible surviving examples within a run based on volume of unique lookups and sequential clustering. Think of it as an adapted histogram for surviving artifacts with serialized production.
Admittedly, the existence of anomalies in these particular runs is difficult to explain and likely a result of noise, but they should be noted.
musicguy
Jan 12, 2017
7,579
4,090
New York State
Reactions: luvsthetick
Tom McIntyre
Technical Admin
NAWCC Star Fellow
NAWCC Ruby Member
Aug 24, 2000
83,960
1,906
84
Boston
awco.org
That is a nice image. Here is the 91 from my collection. It no longer belongs to me. You can see all its images and its fate at this link. AWCo Web
166,113
1,446,960
86,665
Furgus2021
2,883
