Elgin 571 - micro regulator
JeffL
Jul 19, 2010
I recently acquired an Elgin 571 grade RR pocket watch. It is running a little slow and I wish to adjust the micro regulator. All my other pocket watches have an "F" on one side of the adjuster (needle pointer) and an "S" on the other side. This watch has the "F" above the "S" on the same side (the right) of the micro adjuster needle. Can someone please explain the adjuster to me?
Thanks, Jeff
ben_hutcherson
Jul 15, 2009
3,153
348
Kentucky
Move the screw toward the "F" to speed it up, and toward the "S" to slow it down.
It threw me off the first time I adjusted one, too.
MFRC1956
Dec 9, 2008
738
Stockholm, Sweden
When you move the tip of the regulator pin towards the F and S it will make the hairspring longer and the movement will run slower, if moved away from the F and S it will make the hairspring shorter and make the watch run faster.
I see Ben was faster, nice and short explanation Ben!
Michael
JeffL
Jul 19, 2010
Thanks, Very helpful with the picture. My 571 (1950) also has the stainless steel case. Was that common on this model?? Jeff
Kent
Gibbs Literary Award
NAWCC Silver Member
Aug 26, 2000
18,489
1,872
In the data base of reported railroad watches (and other interesting watches) that Ed Ueberall and I maintain, out of slightly over 400 BWR No. 571 watches whose case material is reported, about 30 are in stainless steel cases. That's about 7.5%. Since these were the least expensive of the cases available for the watch, one would think that the percentage would be greater, but such was not the case (so to speak).
ben_hutcherson
Jul 15, 2009
3,153
348
Kentucky
As an aside, please note that it's my understanding that all original cases will have a crescent-shaped notch milled out of the case frame by the regulator screw to enable easier adjustment.
The case on my watch(above) is of the correct style and is signed "Cased and timed by the Elgin National Watch Company", but I don't believe it to be original based on the absence of this slot.
Kent
NAWCC Silver Member
Aug 26, 2000
18,489
1,872
I believe Ben to be right in that the correct case for a No. 571 should have notch in the case rim for regulator screw clearance. Earlier No. 571 cases lack the case model number (3057 for the stainless steel case), but later cases have it. 84921.jpg
Topic related ad experiment
160,717
1,394,681
82,814
mugs
1,099
2,778
