ANDY YALE
I got this watch as a complete, non running movement. On examination, the balance was good, and the train ran well on the high speed test. But the pallets would not function- a busted pallet arbor and cracked pallet bridge jewel.
I replaced both the pallet fork and bridge with parts from the same model Elgin. I got good action on the pallets with the watch wound, and with the balance in, fair amplitude, in all positions, but a little short on the arc.
I completely disassembled it, ran it through the ultrasonic, cleaned the hairspring in benzine, trued the balance in the flat, tightened some loose balance screws, reassembled and oiled the watch and demagnetized it.
Amplitude is better at about 220, but the watch picks up time like crazy. About an hour in every 5 hours.
The hairspring is between the pins on the regulator, but they look a little wide, so the spring is sitting on the outside pin, not in the center of the two pins.
The only other thing I can observe is that the overcoil looks a little bit unusual, the curve is a little tighter than usual to my eye.
Besides the pallets, all the parts of the watch carry the same serial number.
What else could I look for to cause this crazy rate of gain?
