Elgin 0s mainspring question
Discussion in 'Watch Repair' started by bjhallen, Mar 29, 2017.
  1. bjhallen
    bjhallen Registered User
    Dec 13, 2010
    49
    According to the Parts tab on PocketwatchDatabase.com (love that site), I need part 2097 - strength .00575
    Looking on the Bay to purchase a spring I find a number of 2097 springs with .0055. There is only one 2097 with .00575 markings on the package. Then there are white alloy springs marked 2079/6095.
    Question- can someone explain if these are interchangeable and why/why not??
  2. Accutronica
    Accutronica Registered User
    Nov 21, 2016
    553
    I'm not sure but you can get one here: http://www.ofrei.com/page298.html#12828
    Robert
  3. bjhallen
    Dec 13, 2010
    49
    Thanks so much for the quick response....You just enter the SN of the watch and for $29 they send you the right mainspring......wow, but I think I need to save some $$ and understand what the difference is. Enjoying the learning part, too!
  4. Accutronica
    Nov 21, 2016
    553
    I think it said they were on sale for $24.99. Maybe you can find one cheaper somewhere else.
    Robert
  5. richiec
    richiec Registered User
    Feb 24, 2007
    5,456
    I think you can find them cheaper at Dave's Watch Parts, CasKer or on Ebay.
  6. bjhallen
    Dec 13, 2010
    49
    But the problem/question I have is 2097 comes in two sizes/strenghts(?) I see on the Ebay packaging pictures - .00575 says 294 and .0055 says 295
    Some on Bay are selling as 2097/6095 with no indication of 294 or 295 on package.
    Dave's description states 2097 nothing about 294 or 295
    Caskers says 2097/6095 nothing about 294 or 295
    Is 6095 the alloy spring, but is it the .0055 or .00575? Does it matter?
    I'm beginner and I'm confused.....
  7. 18k BPH
    18k BPH Registered User
    Aug 18, 2016
    26
    I recently cleaned and reassembled an Elgin Grade 320 0s and an Elgin Grade 462 3s. They both can use the 6095 mainspring, so I bought 2 from eBay to try them out. I didn't know if these eBay mainsprings were the correct strength as they were unmarked, but after installing these mainsprings the watches ran very fast. I suspect these 6095 mainsprings were too strong. I do not want to use the Elgin Resilient 2097 mainsprings because they are steel and may already be set after all this time. When I find the closest Elgin Durapower (alloy) mainspring, I will try again.
  8. richiec
    Feb 24, 2007
    5,456
    According to the mainspring chart I have, the 2097-.0055 is for the 15 and 17 jewel movements while the 2097-.00575 is for the 7 jewel movements. Hope this clarifies it somewhat. they also made a .00525 thickness but it was unknown what jeweling this covered. All are .065 inches wide and likely 17.5 inches long. Using metric numbers, they are 1.65 mm wide, the 15-17 jewel one is .139 mm thick and about 437.5 mm long. Other numbers for 0 size Elgin springs are 825 for the model 1, 1713 for model 2-3 with steel safety barrels, 2097 for model 2-3 with going barrels and 2328 for model 1 punched(hole?). the 6095 is the durapower spring and has thicknesses ranging from .0051-.0055 and is for the model 2-3 with going barrels. thinner is for the multi-jeweled movements and thicker is for a lesser jeweled movement.
  9. MrRoundel
    MrRoundel Registered User
    Dec 28, 2010
    815
    #9 MrRoundel, Mar 31, 2017
    Generally, higher jeweled movements seem to take a thinner/weaker mainspring. This probably has to do with them having less friction in their train-wheels, etc. What model/grade watch is it, and how many jewels does it have? I might be able to find it in my Elgin parts book.
    I just looked in my book and saw that Elgin calls out 3 different thicknesses depending on the grade of watch. The thinnest, .00525 is in a grade 423-424, .00550 in grades 417-420 and 462-465, others seem to be that .00575. Let me know the serial number, and I should be able to find the grade and the proper thickness.
  10. richiec
    Feb 24, 2007
    5,456
    Thanks for listing the grade numbers because you can narrow the spring down better than knowing model 1, 2 3 etc. I have a master Elgin mainspring list plus the parts catalog listing grade, etc also.
  11. bjhallen
    Dec 13, 2010
    49
    Thanks 18 BPH for information on your experience - valuable. :)
    Richiec and MrRoundel both referred to a book to “look up” – thanks for checking and it confirms the thought that I’m missing a reference book used to “understand” mainspring replacements. Sometimes the hardest part to gaining knowledge is figuring out what you don’t know exists. The Pocketwatchdatabase website did give me the “strength .00575”, but I did not understand that this was the thickness which would equate to strength. THANKS so much all three of you and the person that private messaged me!! :smile:
  12. MrRoundel
    Dec 28, 2010
    815
    #12 MrRoundel, Apr 1, 2017
    YW, bjhallen. The book I referenced is the factory parts book for Elgin Genuine Material. Mine is in a red spiral binder with gold "Elgin" logo and printing. The price list in the back is for 1953, so that figures to be close to copyright time. The book is so well indexed, etc., that it makes one consider working on Elgin watch exclusively. It's too bad that all watch companies didn't do the job as well.
    BTW: It still might be a good idea to let us know the serial number of your watch, or at least the grade number, in order to double-check the information you got from the other website. Your call. Good luck. Cheers.
    Link to completed auction for reference book noted above.
    http://www.ebay.com/itm/vtg-ELGIN-W...D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
  13. bjhallen
    Dec 13, 2010
    49
    Thanks so much for giving the name of the reference book you use. I found it is accessible on the Elginwatches.org (another website I love). Here is what you must be looking at - wow that came out small - but a big thank you!
    [​IMG]
  14. MrRoundel
    Dec 28, 2010
    815
    It's similar, but not exact. I don't see the grade number referenced. But it does show that the 15J and 17J models/grades take the thinner/weaker spring, which is probably the most important part. Good luck.
Similar Threads - Elgin mainspring question Forum Date
American PW Elgin Durapower Mainspring Questions Watch Repair Aug 13, 2013
American PW Questions concerning fixing an Elgin mainspring. Watch Repair Mar 22, 2013
American PW Elgin Mainspring Question Watch Repair Aug 1, 2009
American PW Elgin size 16 mainspring question Watch Repair Jul 22, 2004
