electric clock repair help?
Discussion in 'Electric Horology' started by bobgold, Dec 24, 2005.
  1. bobgold
    bobgold Guest
    I have an advertising clock from the 1940's that needs motor replacement. Is there anyone here who knows the best way to go about this? Thanks.
  2. bobgold
    bobgold Guest
  3. bobgold
    bobgold Guest
  4. bobgold
    bobgold Guest
  5. mrb
    mrb Guest
    depends on the clock and motor.
  6. mrb
    mrb Guest
  7. Tom Kloss
    Tom Kloss Registered User
    Dec 5, 2003
    1,882
    Retired from one job, started another.
    N.E. Pennsylvania
    Please post a picture of the clock and motor assembly.
    Tom
  8. Tom Kloss
    Dec 5, 2003
    1,882
    N.E. Pennsylvania
    Tom
  9. bobgold
    bobgold Guest
  10. bobgold
    bobgold Guest
  11. shutterbug
    43,404
    1,221
    Bob - that does not look like a motor you're likely to find parts for, and it would be a real shame to replace it with a modern motor. You might be able to get it rebuilt at an electric motor repair business. That would preserve the original look of the clock and prevent a large loss of it's value to collectors.
  12. shutterbug
    43,404
    1,221
  13. bobgold
    bobgold Guest
    i've had this clock since 1974 and was able to get going then by rewiring. it has lights inside.
    It worked for some years following that, but now the motor/movement isn't doing the job. Not sure what's wrong. I'm a clock novice but also a do it yourselfer.
    what i can tell you about the motor is that it's 115 volts and there's a manual start for the movement.
    Do you think it's possible to take a motor/movement from another clock and transplant it?
    Bob
  14. bobgold
    bobgold Guest
    Bob
  15. mrb
    mrb Guest
    Aslong as the coil is good this is a simple clock to clean and oil.
  16. mrb
    mrb Guest
  17. bobgold
    bobgold Guest
    how do you determine if the coil is good?
  18. bobgold
    bobgold Guest
  19. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    162
    deceased
    I can't quite tell from your picture, but it looks like a rotor and field type set-up. If it is, you can tell if the field is good by putting a srewdriver up to it to see if there is any magnetism with the power on. If it attracts, the field is good. ( This is an old punch clock field test).
    Harold
  20. harold bain
    40,850
    162
    deceased
    Harold
  21. stewart
    stewart Registered User
    Aug 25, 2004
    478
  22. stewart
    Aug 25, 2004
    478
  23. Tom Kloss
    Dec 5, 2003
    1,882
    N.E. Pennsylvania
    That's a Hammond clock motor. They did a lot of advertising clocks. Try an Ebay search for " Hammond clock " Most of the time the problem with them is not the motor but the first gear the motor pinion drives. It's made out of fiber and the teeth break.
    Tom
  24. Tom Kloss
    Dec 5, 2003
    1,882
    N.E. Pennsylvania
    Tom
  25. gre406
    gre406 Registered User
    Oct 6, 2001
    611
    Bob...try removing the three (3) countersunk brass screws on the front and lifting off the plate....take another photo so we can see the motor better. You may just have to clean the gears underneath and oil...
    Lets have a look........
  26. gre406
    Oct 6, 2001
    611
  27. bobgold
    bobgold Guest
    thank you for everyone's help. i'm at work today so can't photograph the movement/motor with the cover removed, but will do so tonite and post.
    I did already make an purchase of a working hammond clock listed on ebay. the motor appears to be exactly like the one in mine (at least from viewing the back and questioning the seller about the size, but can't be sure until it arrives. if it's not a perfect match at least I'll have some parts to work with. I suspect that i'll have to swap the shaft that the hands mount.
    if not, i think i'm moving in the right direction.
    I especially appreciate the identification of the motor as a Hammond. I'm pretty sure that one was right on the money, even though there's no identifying marks on the motor itself. Again thank you so much for your guidance and help.
    Bob
  28. bobgold
    bobgold Guest
    Bob
  29. bobgold
    bobgold Guest
  30. bobgold
    bobgold Guest
  31. gre406
    Oct 6, 2001
    611
    Well Bob...I think we expected a black gooey mess but it doesn't look bad at all....looks like you cut the wires to the coil...
    Did you power it up and check the field for magnetism? Are all the teeth on the fiber gear?
    Let us know how you make out with the new motor.
  32. gre406
    Oct 6, 2001
    611
  33. shutterbug
    43,404
    1,221
    Your motor really looks to be in fairly decent shape. If your new one is identical, you can swap them out without affecting the value. I'm thinking you can fix it though, and might have two old clocks in working order :)
  34. shutterbug
    43,404
    1,221
  35. bobgold
    bobgold Guest
    Plus I have my eye on another Hammond Clock on ebay, but don't know if that one works. Once i get the my new (old clock) from the seller and confirm that it works, I'll clean and reassemble.
    How does one clean, recondition an old electric movement like this? What do you use to clean the gear assemblies with? What do you use to lubricate? I enjoy tinkering and am mechanically inclined. Seems like another fun project to take on at home. Who knows? Maybe I'll catch the electric clock collecting bug.
    Bob
  36. bobgold
    bobgold Guest
    Bob
  37. bobgold
    bobgold Guest
    Yah, I cut the wires to the coil, perhaps too close. Is it possible to remove the coil, take it apart, without damaging it, and rewiring it?
  38. bobgold
    bobgold Guest
  39. bobgold
    bobgold Guest
    How do i identify the fiber gear you're talking about. I did notice one gear that's much darker in color than the others. Is that it?
  40. bobgold
    bobgold Guest
  41. Mike Phelan
    Mike Phelan Registered User
    Dec 17, 2003
    9,836
    15
    West Yorkshire, England
    #41 Mike Phelan, Dec 27, 2005
    Hi Bob
    I clean electric clocks exactly like any others, excepting the the field coil. I use either white spirit (USA call it paint thinners, I think?) or petrol.
    If really dirty, ammoniated cleaner first.
    Lubricate pivots with turret clock oil, and clock oil on the rotor, unless it has sintered bronze bushes, than I use sewing machine or household oil that 'creeps'.
    If the first stage of fibre gearing is noisy, I put some thin grease on it. It will be the one you mention.
    You can put new leads on coil, but be careful; winding is about .001" wire or less!
    HTH
  42. Mike Phelan
    Dec 17, 2003
    9,836
    15
    #42 Mike Phelan, Dec 27, 2005
    Hi Bob
    HTH
