Edge knife suspension - construction details
Discussion in 'Clock Construction' started by atferrari, Feb 23, 2012.
  1. atferrari
    atferrari New Member
    Feb 23, 2012
    Marine Surveyor
    Buenos Aires - Argentina
    Hi to all.
    After searching the Web for long time with no success I decided to post here.
    My interest is focused on the electronics side of some tests to be carried out on a free pendulum which I need built by a machinist. I lack the tools (and the dexterity for that!).
    Some refined construction would be excellent but not to the point of making this a costly attempt.
    Having elected an edge knife suspension, is it anyone kind enough to give the details of shape / sizes / angles of the V groove and the knife? My pendulum is planned to be about 1 m long with a weight, all in all, between 1 and 4 Kg.
    Of course a suggestion on appropriate materials for the suspension (trying to avoid spending too much $$$) would be nice as well.
    I expect the test to last one year at maximum.
    I would appreciate concrete data, if at all possible, supported by a simple sketch.
    Gracias for the time you will spend reading this. (No pun intended)
  2. tok-tokkie
    tok-tokkie Registered User
    Nov 25, 2010
    262
    Cape Town, South Africa
  3. atferrari
    Feb 23, 2012
    Marine Surveyor
    I was aware of that thread.
    Any chances that I could get a simple sketch with dimensions?
    What is articulated and how, is a mystery for me. Keep in mind that I know nothing of all this.
    Gracias for replying.
Similar Threads - Edge knife suspension Forum Date
beryllium copper grade for suspension spring. Clock Construction Apr 23, 2017
Mystery Clock Suspension. Clock Construction Jul 12, 2016
Suspension spring mounting detail Clock Construction Aug 29, 2015
pendulum weight and knife edge suspensions Clock Construction Jul 4, 2015
