Early Methods of Correcting Middle Temperature Error
Discussion in 'Chronometers' started by Tom McIntyre, Jan 27, 2019.
  1. Tom McIntyre
    Tom McIntyre Technical Admin
    Aug 24, 2000
    81,962
    1,399
    176
    retired SW dev
    Boston
    I think this chronometer is pretty interesting. I am very interested in correction of middle temperature error.
    C4BB67CF-3054-4759-A4DD-55330ED0E37B.jpeg 12244144-B2B2-4A02-A877-DE46A6E88842.jpeg E77F2679-10C7-49AD-8B35-13C349A5895D.jpeg 3E404AF5-2D6C-4408-9C2B-6688F5F86BF2.jpeg C0FECFA5-C0DC-4312-89B0-1099492F96DE.jpeg 72A193F6-B430-45FF-BDD9-0D44EFFD0546.jpeg 576F99D9-ECC3-4B7B-91BB-FB929A8A43F1.jpeg
    Brad Maisto and Levi Hutchins like this.
  2. Tom McIntyre
    Aug 24, 2000
    81,962
    1,399
    176
    retired SW dev
    Boston
    For the general audience, middle temperature refers to the phenomenon where a timepiece that has been designed with a bimetallic balance to run with the same rate in heat and cold (typically 32 deg. and 92 deg.) will lose time when running at the middle temperature ( 62 deg.). I am not sure who first addressed the problem, and it may have been LeRoy with his original temperature compensated mercury balance.
    In any case J. R. Arnold investigated it along with his business associate, E. J. Dent and they came up with a number of approaches. Essentially all of the 19th century approaches involved some additional temperature sensitive part on the balance that would cause the balance to gain time as the temperature moved toward the mid point and then lose that time as the temperature moved toward the other temperature extreme.
    This example is a form of Frodsham's Micrometric balance. This balance has the normal bimetallic rim that moves in with heat and out with cold. In addition it has two arms that are flat and attached (actually formed) in the cross arm and carry a weight at the extreme end. These arms are bimetallic and designed to be flat and in the same plane as the cross arm at the middle temperature. As the temperature goes up, they curve upward and carry their weight toward the center, which makes the rate increase. However, when they cool, they also curve downward toward the center and make the rate increase.
    In Mercer's book on The Frodsham's, this type of balance is discussed and the examples shown have the two middle temperature arms parallel to the balance arm. In this examples they are at an angle which allowed a simpler construction with very slightly less length to the arms.
    I do not know how many of these were actually fitted to chronometers. I am sure there are much more erudite descriptions of it elsewhere, but this is a new toy and I wanted to share.
    I also have a chronometer with the Lund Corrector and one with E. J. Dent's variant on this theme, his staple balance as well as the very common Poole's auxiliary that simply limits the change in the balance in one direction to cause the curve of radius with temperature to be discontinuous.
    Perhaps other readers of this forum who collect these interesting artifacts can show and describe some of theirs.
  3. Tom McIntyre
    Aug 24, 2000
    81,962
    1,399
    176
    retired SW dev
    Boston
    J. R. Arnold's middle temperature corrector is incomplete in that it only compensates half of the temperature defect. In that respect it is similar to the Poole auxiliary, but has a wider range of correctness. By shifting the mean temperature point of the balance, it (and the Poole) are made more effective but still do not completely correct.
    This chronometer has Arnold's type of compensation with a bimetallic arm laid atop the cross arm with a pair of weights on uprights that are thrown inward with the change.
    This chronometer also shows that treasure can be found in strange packages. It is a very small Frodsham marine chronometer with serial number 2274, quite a bit earlier than the micrometric above. The box is an ordinary pine box that some enterprising soul made to hold his chronometer.
    0542094B-8F4A-4E3F-AFAA-2B600A58BDC2.jpeg 58F41A5F-7B60-4BE6-95E4-BB0235808964.jpeg 2D3638F9-205F-406C-AF41-3A9E6465B68F.jpeg 66B5E068-0AC7-44C6-890E-2F9E7A072055.jpeg 98666C09-BF65-45CA-B681-F31004F44234.jpeg 7BC5CD03-03F4-431C-96B9-D44FEB07F88E.jpeg 82E1E156-AE31-47E6-A03C-5686EC11F4E8.jpeg 2DFE2BCE-4976-4B5B-9BC7-2E101584F8E0.jpeg 410EFB48-BBBF-42FE-BE6C-15F34D14C9BE.jpeg B5118A1E-A0D2-4101-8982-253B7DB286FF.jpeg D64A0364-B452-4304-807B-EA8DA3F575EE.jpeg
  4. gmorse
    gmorse Registered User
    10,517
    1,215
    Retired from Xerox
    Hi Tom,
    If these extra parts are integral with the main crossing and are bimetallic, is the whole crossing bimetallic and how does that affect the whole crossing? Or are the brass lamina applied to just the underside of those arms? It's hard to tell from the pictures but I can't see any brass in their edges.
  5. Tom McIntyre
    Aug 24, 2000
    81,962
    1,399
    176
    retired SW dev
    Boston
    #5 Tom McIntyre, Jan 29, 2019
    I have not torn them down and cannot see well under the arm. I believe the design as described in Mercer has the central arm steel and the arms carrying the weights steel on top and brass below. The movement is not large, but the effect of the upward curve in cold and the downward curve in heat was a subject of correspondence between Frodsham and Airy.
    On the Arnold form with the stalks, the vertical displacement of the weight is adjustable and the movement is amplified by length of the arm.
    Airy thought Arnold's form inferior, but with the ability to set the middle temperature with the weight on the main arm, I think it does not matter much. I will try generating some curves from the equation for the moment of inertia vs temperature for the various forms. The calculus was over 100 years old when they were chasing this problem, but I do not see much use of it in the discussions.
    My friend John Huber has a strong interest in these balances also and a few years ago he did a demonstration disassembly and reassembly at our regional meeting in Florida. It occurs to me that we might be able to have a really good discussion on the topic at our National Meeting in Springfield this June. I suspect we can put together a study of at least 5 o 6 different designs and possibly 10 and maybe more if others how up with examples.
  6. Tom McIntyre
    Aug 24, 2000
    81,962
    1,399
    176
    retired SW dev
    Boston
    #6 Tom McIntyre, Jan 30, 2019
    This is the Parkinson & Frodsham that shared the lot with the Frodsham Arnold. It has a slightly enhanced form of Poole’s auxiliary acting in heat. You may be able to see the fixture with 3 available positions to hold the constraint screw.
    A5EA1A43-CB64-4985-B855-5FDAFEBC971D.jpeg 0A46002A-50F7-49DA-BA8C-9D6F504FB742.jpeg B25616F0-5B33-4996-B4AE-F8583EEA770B.jpeg 3FD8B144-E646-450A-BBBD-F2F581C8F753.jpeg EAD9D94C-BE57-4539-8309-FF7C4793376D.jpeg 5F571BA9-D79A-4AA3-8F75-E24A6216BFD6.jpeg
    F4174EF7-D71A-4939-BB76-8370993C8FB4.jpeg 9D7AAC12-A931-4317-9C9F-838491437FD0.jpeg
  7. Paul Regan
    Paul Regan Registered User
    Mar 4, 2003
    675
    Florida
    Looks like Lot 18 landed in the right hands Tom. Congrats on getting the pair.
    Paul
  8. Jerry Freedman
    Jerry Freedman Registered User
    NAWCC Star Fellow NAWCC Member Sponsor
    Sep 16, 2000
    674
    17
    I know I have shown this before, but here is Kullberg's balance with his attempt to correct the
  9. Tom McIntyre
    Aug 24, 2000
    81,962
    1,399
    176
    retired SW dev
    Boston
    Jerry, in the recent auction, this balance in a chronometer signed for Johnson Walker & Tolhurst was described as having Kullberg's "flat rim" balance. I do not have a description of its operation. I tried, unsuccessfully, to buy it. :(
    7EACC9BE-42CE-407A-931B-02FB7F9F7FAF.jpeg B1D5D88F-66EB-48FE-BA50-874618A83B1D.jpeg B452A96D-C611-4EF5-8E27-021BD31C660A.jpeg 467B3837-21AF-445E-8F42-6B98674A5609.jpeg F14D4381-4102-4FC3-9C69-F73583D0FFBD.jpeg E93BB7E3-1101-4BCF-A223-07CDD9635181.jpeg AA6B16B5-551E-4BB4-8991-4361D0168014.jpeg
  10. Tom McIntyre
    Aug 24, 2000
    81,962
    1,399
    176
    retired SW dev
    Boston
    This chronometer from the same sale is signed M. F. Dent. It is an 8 day in a beautiful box with a balance that looks to my eye the same as @Jerry Freedman's example.
    9C273DA3-B4F7-4A93-8ADE-29D259478D60.jpeg 1F66C8A9-47B0-485E-92AB-DAEA6BCDDF1B.jpeg D6A0EA59-40CE-4044-A0FB-D54174104868.jpeg D10CF6C9-6D8F-4F9E-B63A-EE3610068F79.jpeg F9521618-28E8-42A5-8AA5-C0498D0F8456.jpeg
  11. gmorse
    10,517
    1,215
    Retired from Xerox
    Hi Tom,
    Kullberg's flat rim design is described in Gould.
    By the way, I was interested to see the Walsh pocket chronometers 311, 312 and 186(4); there didn't appear to be any frame makers' marks on them but the frames look identical to one I serviced recently, made by Joseph Preston, and finished by John Hammersley, (with a duo in uno balance spring), for M.F Dent.
    It also had the steel detent stop which wrapped around the balance lower jewel with the adjustment by a screw through the extension, (slightly bent as received).
  12. Jerry Freedman
    Sep 16, 2000
    674
    17
    Tom: Page 90 of Whitney's has a good drawing of Kullberg's balance. My addition of Gould's book has a drawing of Kullberg's flat rim
    balance.
  13. Tom McIntyre
    Aug 24, 2000
    81,962
    1,399
    176
    retired SW dev
    Boston
    I dug out my copy of the second edition of Gould and have been reading the section on middle temperature error.
    upload_2019-2-2_14-43-40.png I think he does a good job explaining why the discontinuous balances of the Arnold type function as well as they do and also why the Poole was so popular in comparison to the more complex forms.
    The discussion in Mercer that revolves around the correspondence between Charles Frodsham and Airy on "true" middle temperature correction with a mass moving inward in both heat and cold is a little clearer than the similar discussion in Gould. Gould does capture it well in his description of the action of Lund's Corrector (which is renamed from the erroneous Barraud's Corrector in the first edition).
    He also give a nice clear discussion of Loseby's balance which is conceptually much simpler than the others since it only requires you to make a cycloidal curved thermometer to match the hairsping's linear change with temperature. (Which no one except Loseby and Robert Gardner were ever able to do. :))
    I will try to read Whitney later this evening.
    The diagram is a simple illustration of the middle temperature problem that I drew for my presentation on the Evolution of the Marine Chronometer some years ago.
  14. gmorse
    10,517
    1,215
    Retired from Xerox
    Hi Tom,
    In the October 2018 edition of the Horological Journal there's part 2 of a series of articles on balance springs by David Boettcher. In it he goes into some detail on the source of middle temperature error, including the conclusion that 'Dent's anomaly' was based on an erroneous supposition, namely that the turning force of the balance spring varies linearly with temperature and makes little or no contribution to the observed error, all the blame being placed on the moment of inertia of the balance varying with the square of the radius of gyration. Later investigations, (by E.T. Loseby, Dr. Guillaume and Philip Woodward amongst others), revealed that the balance spring's thermoelastic response is not linear but actually quadratic, and constitutes the major component of middle temperature error. Well worth reading!
  15. DeweyC
    DeweyC Registered User
    Feb 5, 2007
    1,659
    514
    Watchmaker
    Baltimore
    This is a very interesting topic.
    For those interested, there is an article in the February 1991 Bulletin containing pictures, descriptions and an analysis of the approaches to reduce middle temperature error. I included Poole, Hartnup, Kullburg, Guillaume to name a few. If you are a member you can access the article via this link:
    http://docs.nawcc.org/Bulletins/1990/articles/1991/270/270_41.pdf
    Since selling those instruments, I did come across a staple balance and I will post a photo of it later today. It and the Hartnup balance follow a similar conceptual approach but are different executions. Of course, Guillaume was awarded the Nobel prize for his work to produce the "perfect" mechanical oscillator in 1922. This whole area shows human beings at their best.
