Hello, I recently purchased a longcase clock for $80 that needs work. Purchased as-is unknown condition. This is the first time working on a longcase clock so I am learning as I go. I started off with some minor cleaning (air dusted and applied some clock oil in certain areas) just to get an idea how much work might be involved.
The clock came with 4 weights detached with no cables, but the clock appeared to only require two weights. Someone at one point tried to use electrical wire. I added 50lb braided fishing line (approx. 1mm thick) and set up the weights. I am thinking to find thicker cable but I am leaving for now for testing. One weight is 7lb and the other is 8lb.
The base that attaches to the movement was upside-down which would have caused the cables to rub against the movement base - I flipped it back to how it should be so there is no contact. The extra weights are much heavier and probably was used as an attempt to get the clock running, but with that base installed incorrectly my guess is even that did not work out.
It took a few restarts of the pendulum just to keep it going. I figure the movement needed to run for a while being that it probably sat for years. The clock is running now and seems to keep time.
What I noticed online is that these clocks usually have a pulley system. I don't see holes for the cables to feed back up through the base of the movement and there were no pulleys so I installed the weights without.
Are there longcase clocks that do not require pulleys?
The dial indicates the clock was made by Rob McAdam from Dumfries.
Ca. 1820 or 1830? This is my best guess based on some research.
Attaching some photos. Thank you!
Old cable - Base installed upside-down
New cable -Flipped base to align holes
Weight attached - No pulley
