Clock E.N. Welch Verge & Saddle
Discussion in 'Parts Wanted' started by dashley, Aug 16, 2019.
  1. dashley
    dashley Registered User
    Apr 30, 2015
    136
    Tennesse
    E.N Welch Verge Saddle with pallet.
    I have an E.N. Welch movement I'm trying to restore. The Verge is missing. It's an odd size verge.
    The saddle is narrower than most (I pulled one off of a similar movement). See pic verge1 below for measurements. The verge pin sits approx 6.5 mm high. The escape wheel has 52 teeth (The similar movement I have has only 40 teeth.)
    The Frame is stamped see pic 52Tall:
    E N Welch
    MFG. Co
    . The escape wheel was mangled when I received it. May wind up replacing it too.
    If you need anymore info please let me know.
    Thank You
    -dan
