E. Howard Watch Works pocket watch #3651 year 1863
Discussion in 'American Pocket Watches' started by markhowe, May 19, 2017.
  1. markhowe
    markhowe New Member
    Jun 17, 2016
    #1 markhowe, May 19, 2017
    I have my ggfather's pocket watch watch and a letter from E. Howard Watch Works identifying it: #3651 year 1863. Letter is from W.W.Cook
    Is that enough identification for getting a rough evaluation?
    My email is markhowe@cox.net if anyone wants to contact me directly for photos and background.
    A bit of background, he was the Supt. on the Iowa Div. of the Chicago & NWRR from Clinton to Council Bluffs 1861-1879. [C&NWRR conference is this weekend. wish i was there.]
  2. musicguy
    musicguy Registered User
    Jan 12, 2017
    929
    10
    New York State
  3. JTD
    JTD Registered User
    Sep 27, 2005
    3,950
    19
    We are not allowed to discuss values on this part of the site, if that is what you mean by getting 'a rough evaluation'.
    In any case it would be better to post your request (and photos) on the pocket watch section, rather than in 'clocks general'.
    Maybe one of the moderators will move your post for you.
    JTD
  4. Dave Coatsworth
    Dave Coatsworth Super Moderator
    Donor NAWCC Member
    Feb 11, 2005
    3,994
    Camarillo, CA
    Moving to the American Pocket Watch section.
  5. John Cote
    John Cote Registered User
    Aug 26, 2000
    3,412
    11
    Photographer
    Midwest USA
    Mark,
    As was said above, if you post a picture of the dial and the movement/works of the watch we can tell you a lot about it. The serial number is pretty low. It sounds like it will be a series III but there are a lot of variations. Sounds like a very cool watch.
  6. MrRoundel
    MrRoundel Registered User
    Dec 28, 2010
    820
    Real Estate Broker on hiatus
    So. Cal., USA
    20+ years ago, when I first got into pocket watches, the first watch I owned was a Howard. But mine was a Keystone Howard, not an E. Howard & Co. from the earlier company. Not long after, I remember gravitating towards the Series III. There's something about the way it's put together. Great quality is obvious, and the steel parts are beautifully finished. They're great watches.
    As John Cote says, there are variations, mostly in the type of regulator that's on the watch. However, another variation is the earlier watches that had the balance-wheel above the center-wheel, where the later models were all slimmed down a bit and had a more common configuration (At least with 3/4 plate watches.) with the balance under the center-wheel. I'm guessing that yours is the earlier, balance-over, type.
    We could certainly provide non-value information, that you yourself might find valuable, if you can provide images. Cheers.
  7. Clint Geller
    Clint Geller Registered User
    Jul 12, 2002
    917
    I am a research physicist at a government lab
    Pittsburgh, PA
    #7 Clint Geller, May 20, 2017
    There are many variations among these early Series III (Model 1861) movements besides the regulator. The Howard factory records state that S# 3,651 has a "chronometer balance" (i.e., a temperature compensating bimetallic balance), "Set Jewels," meaning that the train jewels are in settings (which might be either screwed down or spun in), a "Patent Regulator" (which in this period, meant Mershon's patented compound rack and pin regulator), and adjustment to isochronism (i.e., constant rate, independent of winding state), but not adjusted either to temperature or physical positions. The records do not suggest that this movement has "rayed" plates, so one may safely assume that the plates have standard gilded finish, especially since all known rayed movements left the factory fully adjusted (though adjustments weren't being marked on Howard's standard movements yet). The case screws (two of them) were down on the pillar plate in this Serial number range, like the earlier Series II (Model 1858 divided plate, Types D & E). The pallet bridge style is also shared with the earlier model. Examples with escapements with upright pallets are also known in this serial number range, though they are rare, so the movement should be checked for this feature. In this serial number range, the dial may be a Type 2 (See Geller, NAWCC BULLETIN, August 1993) with a straight, two-line script signature, or a scarce one-line script signature.
    More information is available in the Howard wiki on this website, here:
    http://mb.nawcc.org/showwiki.php?title=E_Howard_and_Co
    That wiki contains a reference to my 2005 book on Howard watch movements, which contains even more information.
Similar Threads - Howard Watch Works Forum Date
1860s (?) E. Howard & Co. pocket watch American Pocket Watches Sep 10, 2017
Help with date for E Howard series II RR pocket watch American Pocket Watches Aug 20, 2017
E. Howard pocket watch case. Solid Gold? American Pocket Watches Apr 22, 2017
e. howard watch works ~ howard watch American Pocket Watches Nov 14, 2010
E. Howard Watch Works vs Keystone Howard? American Pocket Watches Feb 12, 2004
