E. Howard IV has screws showing from under bezel
Discussion in 'American Pocket Watches' started by Kerry Chipman, May 9, 2019.
  1. Kerry Chipman
    Kerry Chipman Registered User
    Mar 16, 2017
    119
    22
    This watch is slipping a little on the time setting and someone mentioned that the small things sticking out might be a lever and this might be a "combo" set and maybe I could pop the bezel off and put the lever on the outside. Well it turns out these are small screws sticking through the bezel. Is this a common thing? How would a watch person describe it?
    You can see the screws sticking out around the 4 o'clock and 11 o'clock positions.
    The two picks showing the screws have the bezel removed.
  2. shovelhead
    shovelhead Registered User
    Sep 20, 2009
    91
    26
    Machinist
    Placerville, CA
    The screws hold in position the push spring & the lift spring.
    Keith R... likes this.
  3. Kerry Chipman
    Mar 16, 2017
    119
    22
    Does it do any kind of adjustment to the watch timing or anything related to setting the time slipping? Sounds like something I should just keep my untrained hands off of?
  4. gmorse
    gmorse Registered User
    11,285
    1,583
    Retired from Xerox
    Hi Kerry,
    These are only part of the case and nothing to do with the movement at all, so best not to touch these, or, as you so wisely comment, anything else whose purpose isn't clear to you!
    musicguy likes this.
  5. Rick Hufnagel
    Rick Hufnagel Just Rick!
    NAWCC Member Donor Sponsor
    Oct 25, 2018
    1,507
    2,135
    Plumber
    Pittsburgh pa
    Kerry, there's many little parts that make up the keyless works that wind and set a watch. None are accessable without dissasembly. There could be various things causing the skipping.
    Sounds like it needs a good servicing, or if it has been recently, take er back.
    Have a good day!
  6. musicguy
    musicguy Moderator
    NAWCC Member Sponsor
    Jan 12, 2017
    5,896
    2,863
    New York State
    I would also ask when was this watch last serviced. As said above,
    if it hasn't been serviced recently or you don't know the
    service history than that would be a priority.
    Rob
  7. Kerry Chipman
    Mar 16, 2017
    119
    22
    Thanks everyone. It's unknown when this was last serviced and we'll get that done by a pro.
    Rick Hufnagel likes this.
