The first time i got a Adjusted Hound I was informed in this old thread https://mb.nawcc.org/threads/e-howard-co-pocket-watch-gamble.161995/#post-1297822 By Clint Geller that these adjusted hounds are hard to find and they have the RR engraved on the side of the balance cock.
Hello, Larry,
There is bad news and good news. The odds are very high that your watch is not lever set, and that your case is not original. However, you lucked out anyway, for a completely different reason!
You will notice that the beveled outer edge of the balance cock of your movement is marked "ADJUSTED," indicating a movement adjusted to isochronism, temperature and 6 positions, whereas the top plate is engraved with a hound, which normally designates a movement adjusted only to isochronism. These contradictory markings only appeared together on a handful of hound-marked movements that were upgraded for sale in the railroad watch market before leaving the Howard factory. The serial number of your watch is in exactly the range when these things happened. If you look on the vertical edge of the balance cock adjacent to the regulator screw, you should see the letters "RR" engraved there. I have seen fewer than a dozen of these "RR" - marked movements over the years. They are slightly more common in the N Size open face Model 1884 ("Series VIII"), than in the L Size hunting case "Series V" (Model 1869), which is what you have. I have probably seen fewer than half a dozen L Size RR-marked movements, all of which were nickel. Please confirm my inference about the "RR" marking on your balance cock. Howard was rarely completely consistent about anything.
If you are always this lucky at "gambling," remind me never to play poker with you.
Congratulations. "
Well im about to post up pictures of my Newer one that I have had for a little while now, but just never showed it off. My newest one is so early it doesn't even have RR engraved on the side.
Here are the pictures of the first one that I ever owned. I sold this one off to a collector that really wanted it ONLY BECAUSE i had seen this one for sale somewhere else. So I basically traded it off to get the new one and made some cash on the side.
Hello, Larry,
