I am going to need a little help from the experts here. Picked up this E. Howard & Co. Boston #89 regulator this morning. The man's story was that in the 1930's his Grandfather got this clock when a Bank was remodeled. He did not want it to hang on the wall so he inverted the door and moved the movement to the bottom of the case to make it a floor clock. Everything is original except it is upside down. Not very attractive that way.
It is missing the suspension spring and weight. The cable broke when he was a teenager and there was enough cable left to use just one pulley and made it a 4 day clock. I need to know where I can order a new suspension spring as it takes a larger spring than I have in my supply? Also how heavy is the weight needed to drive this clock?
My first move is to invert the clock back to a wall clock, clean and oil the movement. Then obtain the parts to get it running again. Any suggestions or ideas will be appreciated. Thanks
